5lug Conversion q's??
808Gt
115
Hawaii
I have been reading for awhile about how to do it and stuff and been planning on doing sometime next year or so....
But i jus wanted to knw about the 5lug conversion that 50resto has... did anyone buy this??
I am planning on buying the kit and jus buying a rear disc break kit for the rears. Also if i wanted better rotors like bear or brembos etc. would they fit (i knw stupid questions bt I have no idea so). Any other information would be helpful to.... thanks in advance.....
well that is a good kit but you will have issues with gettin your center cap on with the rotors (or so i heard).. i choose to go with sn95 setup.. your offset is perfect for the stock offset on a sn95 wheel. Plus its already 5 lug disk, and you can upgrade to 04 cobra brakes like me.
You may want to call tirerack and get some specs for the wheel or even better look up a wheel for the 84-86 SVO mustangs since that is the rotor you are looking at using.
For the $399.95 that 50resto wants I would go a different route to ensure that they fit. You can get an SN95 setupwith everything you need at a local salvage yard or ebay for about the same price or less. Not to mention the SN95 set up is easily upgradable to the 13 inch brakes later.
isnt that what i just said :crazy: lol
If your gettin those wheels, and/or upgrading the front brakes in the future do NOT get the 50resto kit.
I put it on mine and am ver happy with it, but I will not really be upgrading the brakes soon, and I am sticking with factory ford wheels of some kind or another.
I just doubt the center caps will clear the dust caps on those rims, but as far as the kit goes it is extremely easy to install and it is good because they include all of the oil and bearings, ect. to do the job.
-adam
thanks for all your answers...... HAPPY NEW YEAR by the way........
I have been reading on this conversion for awhile and wanted to know if i would be fine with the rear drum kit/ranger axles on ebay and 50resto?? and also the rims are going to be 25mm offset should that be fine, i dont want to have different offsets??:shrug:
just read the web pag on the 5 lug conversion...... and I think i found my answers..... for the front brakes i will be doing the regular conversion that everyone is doing just im gonna keep the drums in the back for now....
So if i read correctly, the front will be ok for the 25mm offset, and the back as well.... and since it is a 17x7.5 or even a 17x8 wheel i wouldnt have any rubbing problems??
