5spd or auto?
  • Thread starter Thread starter Slobin3d
  • Start date Start date Dec 11, 2011
Slobin3d
246
17
38
Dec 11, 2011
  • Dec 11, 2011
I'm torn, I really like driving a stick, and want to install a 5spd in my car, but I picked up a aod trans for next to nothing.
For hiway driving I doubt I'd notice much difference between the two, as far as cost, the AOD is a 4WD trans so it will need to be converted to 2wd, but was rebuilt about 1k ago so all the internals are brand new, or I can pick up a t-5 with bellhousing for $500
What should I do, should I be happy with auto, and maybe do a new valve body and shift kit, or invest in the t-5 and pawn off the aod and jam gears?
I can't make up my mind, please give me some quality pro's and cons to either
R
Rmoore45
142
Dec 11, 2011
  • Dec 11, 2011
If you go with automatic, you'll probably end up switching to a T-5. I would sell the auto trans a buy a T-5. The smiles per gallon is higher with manual.
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Dec 11, 2011
  • Dec 11, 2011
Look at yourself down the road and see if you would be happy with the auto. I would prefer the T5 myself.
gikort
82
Dec 11, 2011
  • Dec 11, 2011
I had the same dilemma when I rebuilt my 67. I went with the auto, 4500 miles later I just finished putting in a T5. Ended up costing me A LOT more.
rbohm
6,698
550
204
tucson,az
Dec 11, 2011
  • Dec 11, 2011
tough choice imo. back in the day, i would have built the car with a manual trans and been done with it. today however i plan on using an AOD when i get around to working on my stang.
build the car like you want it and be happy with the end result. if you really want a manual trans, sell the AOD and get the T5.
jackson0215
101
  • Dec 11, 2011
Put in a manual, your not really driving unless you use both hands and both feet!
Reactions: Fstbk
Slobin3d
246
17
38
Dec 11, 2011
  • Dec 11, 2011
Since I have the auto already, and the current Trans is the FMX, should I consider installing the AOD, and pick up and build the t-5 and do it later? I already have a second motor for the car, maybe do a complete powertrain swap, New 408 with a new t-5 and rock the AOD with the original 351? Is it worth the effort?
Fstbk
215
  • Dec 11, 2011
I put a Z spec T5 in my 65, I will never regret that! But, in your last post you mention a new 408 with a T5? I dont know if the T5 likes much more than 350HP with an aggressive driver with sticky tires, but then again, a AOD may not like it either.
69Rcode_Mach1
1,473
Salt Lake City, Utah
Dec 14, 2011
  • Dec 14, 2011
I'm going throw another vote for the T-5. When you were a kid did you sit in the car and pretend to shift out of park? Row the gears!!
Admin Dude
Jan 4, 1985
43,357
21,561
234
Box behind Walmart
Dec 15, 2011
#10
  • Dec 15, 2011
  • #10
How old are you?
What do you do for a living?
City commute?
Are you a coffee drinker?
Are you married or have a serious girlfriend, and if so, do you generally drive your car or hers?
What gear set do you have installed in the rear?
Is the Mustang your only car?
Slobin3d
246
17
38
Dec 15, 2011
#11
  • Dec 15, 2011
  • #11
Noobz347 said:
How old are you?
City commute?
Commercial Glaizer/Retail Manager
5 miles
no
G/F-- Mine
Haven't decided
no, I have 2 others DD's
Admin Dude
Jan 4, 1985
43,357
21,561
234
Box behind Walmart
Dec 15, 2011
#12
  • Dec 15, 2011
  • #12
I would go with the 5spd then. Purely for the fun factor. My Stang is not my DD either. I get her out and bang gears, leave tread, and cruise whether it's frustration I'm trying to work out or a really great mood that I'm cruising through... either way, I just can't see getting that same level of therapy from an auto.
StreetsideStig
1,012
48
48
Dec 16, 2011
#13
  • Dec 16, 2011
  • #13
I haven't owned a car with an automatic in years, and I've never regretted it. In fact, when I drive one now with an automatic, I find myself bored out of my mind and unimpressed with the response time. I'd go with the stick.
Edster
500
League City, Texas
Dec 18, 2011
#14
  • Dec 18, 2011
  • #14
If it were up to me I'd go 5spd. More fun and can be more fuel efficient. Lighter etc.
iskwezm
4,159
20
79
Rowland Heights,California
Dec 19, 2011
#15
  • Dec 19, 2011
  • #15
I went from a built c4 with a 3000 stall to a t5.Now its time to go back to a built c4.Gas mileage is not a consideration so that has little to do with going back.
Hack
1,945
Minneapolis
Dec 20, 2011
#16
  • Dec 20, 2011
  • #16
I'd say auto vs manual is mostly a personal decision. It seems many people go with auto now-a-days, but we are a little more car crazy than most, huh? I'm thinking about keeping the automatic in my '70, but it's a convertible and the auto will help me drive in a more relaxed fashion. I'm going to try to keep it a cruiser.
I wouldn't put a T5 in anything but a stock 302 with street tires. If you drive aggressively or use sticky tires go with a stronger option. Many people have destroyed T5 transmissions with all factory 302 Fox Mustangs.
chris66dad
167
Benicia California
Dec 20, 2011
#17
  • Dec 20, 2011
  • #17
It is a personal choice above everything else.
I am very happy I went with a T5.
With a built 408 you will want to look at a T5z, G Force or Astro T5.
The basic Astro A-5 is rated at 485 ft/lbs of torque and 550 hp.
The upgraded A-5 is rated at 575 ft/lbs and 650 hp.
http://www.pro-forceperformance.com/astro_a-5.htm
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Dec 20, 2011
#18
  • Dec 20, 2011
  • #18
You can build AOD's to handle up to about 1000HP. No Joke. I've got an AOD in mine with a 1-2-3/OD VB in it with o/d lockout. Its a great setup. I'm planning on putting 3.73's in the back as the 3.00's ive got now are way too boggy on the hwy. The t5 and the AOD are pretty comprable as far as gearing...you might notice a slight difference but not much. Also you can set up the VB to be anything from stock to it shifts so hard your teeth rattle out. They're a very solid setup and I enjoy mine very much.
My main reason behind staying with a auto vs a t5 is that its an original auto car and I'm just trying to upgrade, not radically change it. just my $0.01
stillridin
32
Wesley Chapel FL
Dec 20, 2011
#19
  • Dec 20, 2011
  • #19
Definitly stick. So much more fun.
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
Progress Thread 1978 Mustang II Rallye Overhaul (302, C4, T-Tops)
  • balaseca29
  • Dec 12, 2024
  • 3 4 5
4K
1974 - 1978 Mustang II Talk & Tech Jun 13, 2025
balaseca29
