5th Gear Concern
Acid7711
41
TN
Lately, I've noticed that if I shift into 5th gear going bellow 50mph that if I try to accelerate a little harder than normal, it sometimes seems to "slip" for a second. Just a split second, then goes then sometimes once or twice more. What is causing this? It's a really annoying feeling. It only does it in 5th gear. Every gear goes in without crunching and feels really nice. Could it just be a clutch out of adjustment? I've heard the stock setup sucks for that. I hope it isn't anything bad. Car is basically stock with only an h-pipe and catback.
Thanks in advance.
what are the rpms at in 5th when you shift at 50mph? im sure if you have stock gears you would be right around 1000rpm. thats a little low to accelerate fast in fifth....even for a mustang.
I think it's about 1500-1600rpms. Maybe that's just it. I'm used to driving a higher reving import and this thing seems like it likes to be shifted at about 2k. What does everyone recommend a good rpm to shift at? I try to baby this car and not drive it hard, keeping the revs low for the most part. It just seems to me that after like 2k, it sounds like it wants to be in the next gear, and when I shift around 2k in 4th gear, it puts 5th at about 1600ishrpms.
I really don't know what gears are in there now. I have 3.73's waiting to be installed in a week and a half. Saving up money. I hope it doesn't already have 3.73's in there.
I agree with you on the shift point....I can't stand cruising at over 2000 rpm in town....5th gear is different however. The 5th gear in our cars is quite a drop from 4th gear, so you'll have to rev 4th a little longer than the other gears.
Ok, That's what I was thinkin, maybe just hold 4th out because I did notice, like you said, 5th really throws the revs way down. When I ride 4th until about 55 and on, it goes right in and rpms are nice. Doesn't do that slipping thing it was before.
I really hope it's not a slipping clutch. The guy who I bought the car from (friend and reputable) told me he installed a heavier than stock clutch into it not very long ago.
