6 speed??? tranny
lookout4mepart2
18
Could someone plz help me with this
I need a transmission i had a automatic before i am swaping it for a stick
ok
I have a 1967 mustang coupe with a 351c
I was looking at the tremec web page and found a 6speed stick
http://www.5speedtransmissions.com/6sppage.html
I dont know what to go with?
the 6speed is for a 86 mustang i belive that it had the same stock bellhouseing as a 302 in 68 and same spindles?
http://www.5speedtransmissions.com/tremec_tr-3550.htm
could you plz help me out with finding a tranny.
I am going to **** in my pants....................lol
WTF do spindles have to do with a trans? They never made an '86 with a 6spd anyway. If you want a 6spd, look at gp001's Richmond install or grab a blowtorch, hack a big hole, and bolt in a Tremec T56. Either way, open the wallet...WIDE! :D
HTH
--Kyle
I like it. I put a Richmond 6spd in my 70 Boss 302. One thing to consider is that with 6spds, you row quicker thru the gears. I chose the Richmond due to the bragging factor since it is a real Boss car. If it was a standard Mustang, I would have chosen the T56
Depends on if you want to cut up the car. I have a 67 FB with 351C as well. I put in the TKO without cutting. The TKO 500 fits perfectly.
You can use old or new style bell housing and clutch. You just need to pick which style. I have the old style.
Also, you can go with hydraulic clutch mechanism with either bell/clutch just make sure they all match.
t-56 pics.
I have a t-56 bolted in my 66 coupe and it does take some cutting to make it work at the correct 3 degrees needed to cut down on the vibration. Here a pic...
Never mind the FILE is too large? Is there anyway to reduce the file size? I just bought a Mini coope S with the 6 speed and now I cant wait to drive mine with twice the horsepower.
check Modern Driveline
if you go 5-speed, there will be no surgery required (TKO500 or 600):
http://www.safepay.net/cgi-bin/shop/cart.cgi?db=mddata.txt&category=Transmission&merchant=moderndriveline
and if you really want to go crazy with the gears and 5 ends up not being enough you could put a Gear Vendors splitter behind it. 10 gears, baby!
Here's a good article on the swap and options:
http://www.fordmuscle.com/archives/2005/03/T56Swap/index.php
(may need a paid membership to view whole article)
Hack said:
BANNED!!!! :fuss:
:D
:rlaugh: LOL! Hack, don't worry, I still bleed Ford Blue, I have two other Mustangs to prove it, but that Camaro is sure nice! Runs 11.25 @128.
65Mistress, if you closely look at the trans pic, I had to remove about .25" of sheetmetal from the left side of the shifter hole. I plan on smoothing it and framing the perimeter with a band of sheetmetal to make it look oem...no big deal.
Steel1212, thanks for the thumbs up.
Frank
