64-65 Turn Signal Switch Difference?
  • Thread starter Thread starter tylerrocks
  • Start date Start date Jul 6, 2009
T
tylerrocks
514
Big Spring, TX
Jul 6, 2009
  • Jul 6, 2009
I havn't posted here in a couple years, been sunk with college and the stang stays at home because it's not legal. I've been working on it and I need a turn signal switch. This will be about the third one I've put on it. The contacts are faulty, the ohmmeter reads an open circut from power wire to signal contacts in all positions. I jumped the switchwith power and it lit the lights.
So my question turns to product selection. The car was originally a generator (64.5) car that was switched over to alternator. It looks like an original wiring harness was left in place (prev owner). There is a big price difference ($24 to $89) between a 64.5 model and a 65-66 model switch. I found one recipt for a 64.5 model (the last one most likley) but I can be sure I've never used a 65. Does anyone know the differencs between the two? Or why I might be going thru so many switches?
Does D. Hearn still post here?
This is my new (less expensive) hobby: kayak fishing
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jul 6, 2009
  • Jul 6, 2009
Too easy. The 64 has a single contact and ring, the 65-66 has two. If you buy the wrong one, you may as well have a Nova part, it won't fit.
T
tylerrocks
514
Big Spring, TX
Jul 7, 2009
  • Jul 7, 2009
Thanks. Guess I'll just have to shell out the cash on a 64.5 . Any thoughts on why the switch keeps going out?
2+2GT
3,333
10
79
Jul 7, 2009
  • Jul 7, 2009
What steering wheel are you using?
Have you adjusted the gap between the column and wheel?
T
tylerrocks
514
Big Spring, TX
Jul 8, 2009
  • Jul 8, 2009
Some Grant wheel. I never adjusted the gap but there is very minimal gap. I took the switch apart today and found the culpret. There is a brass head on the back side of where the power wire comes into the switch, a contact wiper is routed under that head to the signal contacts. Put the ohmmeter thru the head and the wire and it was an open circuit. Twisted the wire back and forth a bit and it closed the circuit. The plastic was i bit melted around the power wire, which probably explains the odd open circuit. The wires in the trunk are a little rat chewed so they may be shorting a bit.
2+2GT
3,333
10
79
Jul 8, 2009
  • Jul 8, 2009
tylerrocks said:
Some Grant wheel.
Glad it worked out. You should be using a real wheel, like this one. Twice the price of the Grant, 10 times the quality.
T
tylerrocks
514
Big Spring, TX
Jul 11, 2009
  • Jul 11, 2009
Twice the price to replace a functioning wheel is not an effecient use of my limited funds. After I get my engineering degree I will have more room to splurge on the details.
Electrical Test headlight switch
  • Dontknowchit
  • Mar 25, 2024
3K
Fox 5.0 Mustang Tech Apr 1, 2024
Dontknowchit
L
Fox 88 stang, no turn signals
  • Lizard500
  • Jun 3, 2023
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 3, 2023
Lizard500
L
Electrical - 12v on a ground wire WTF?
  • 65-Fstbk
  • Apr 26, 2023
3K
1965 - 1973 Classic Mustangs -General/Talk- Apr 27, 2023
65-Fstbk
J
  • JRC99
  • Apr 19, 2025
JRC99
J
Horn Contacts help I'm desperate
  • Nick Bos
  • May 26, 2021
Classic Mustang Specific Tech May 28, 2021
7991LXnSHO
