  • 1994 - 1995 Specific Tech
65 mm throttle body
  • Thread starter Thread starter Kevin R.
  • Start date Start date Oct 21, 2004
Kevin R.
473
Ohio
Oct 21, 2004
  • Oct 21, 2004
Would putting a 65mm throttle body on a stock intake/stock motor create any noticable gains?
Also, are they hard to put on?
Thanks.
SN95StangMan
1,292
Lynwood, CA
Oct 21, 2004
  • Oct 21, 2004
That was one of the first things that I put on and didn't notice any difference other than a slight whistling sound at part throttle.
It felt like it gave the car a little bit better throttle response, but that was probably just in my head.
It's shouldn't be too hard to install, even if it is your first time.
BlackVert
5,589
9
98
Bethesda, MD
Oct 21, 2004
  • Oct 21, 2004
the opening is bigger, so your stock intake tube probably won't fit it.
lower intake is most restrictive (replace the upper at the same time), then the mass air meter housing, then the heads. after those are opened up, then the t/b might make a difference. until then, you are not likely to see much difference.
my 70mm BBK t/b is going on in the next few days.
fwiw, i have my stock mass air meter back on for a few weeks until i can get the injector slopes dialed in, i just replaced my fuel pressure regulator.
my $.02
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Oct 21, 2004
  • Oct 21, 2004
No you won't. The 65mm throttle body is bigger than the opening of the stock upper inlet. You would have to port the opening in order for them to mate up perfect. The money would be spent better on another mod like a short shifter or better yet gears (I don't see those in you sig)
Venom351R
4,548
41
98
MAINE
Oct 22, 2004
  • Oct 22, 2004
YAY more noob questions
like wytstang said, it wont make any diffrence. Once you get an aftermarket Intake then a bigger TB will match up to it. Spend your money else where, either on gears or towards a better intake.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 22, 2004
  • Oct 22, 2004
my $.02
After you get things dialed in and berore you change from your stock maf it would be interesting to see a what your maf values would datalog at max rpm. You would see how close you are to maxing out the stocker.
Later
Grady
Nik_95Cobra
1,677
Tempe, Arizona
Oct 22, 2004
  • Oct 22, 2004
Didn't even make a difference powerwise on my Cobra...Other than Fixing the idle issue I had.
Kevin R.
473
Ohio
Oct 23, 2004
  • Oct 23, 2004
And thanks for being so rude about it. I searched first for "65 mm throttle" "throttle body", etc. I found nothing that answered my question.
Thanks for the response. I want gears but was just looking for something I can install myself. I'll look elsewhere.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 23, 2004
  • Oct 23, 2004
Kevin
When starting to mod the motor some parts don't give as much of a power gain as others.
It's kind of a bummer to replace those kind of parts and not be able to feel much if any performance gain and there is the outlay of cash for the parts which just makes it even more disappointing.
See my sig for an example. I did not replace the tb, maf, & catback cause they are low power gain parts.
If your goal is to do the complete NA combo thing then all of the parts will be upgraded by the time you are done.
Not sure what your goals are but IMHO an intake would give you a nice gain and the install is not too hard.
Later
Grady
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Oct 23, 2004
#10
  • Oct 23, 2004
  • #10
The stock upper is 63mm at the TB runner, so you only have to grind out 1mm from the circumfrence - easy to do your self. Another thing that helps is to grind down the upper intake bolt hole bosses down inside the TB runner, but that is not easily done - need 6" bur bits.
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
M
94 Mustang gt throttle body
  • Mike3
  • Jul 26, 2025
1994 - 1995 Specific Tech Sep 2, 2025
revhead347
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Help finding throttle body
  • jpmaxx
  • Apr 21, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 22, 2026
jpmaxx
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
