65 mustang body parts
bnichols04
45
I am restoring my 65 mustang coupe and I am trying to get rid of all these parts sitting in my shed. I would like to find someone that would be willing to pick these parts up from me. I live in ypsilanti, Michigan near the detroit area. If you would be intrested in getting these from me drop me an e-mail at: [email protected] and I will send you pics of them.
trunk lid
RH & LH door shell w/ door pannels & old handles
hood
front valance
front stone deflector
LH & RH fenders
68 rear bumper
rear valance
LH front rocker patch
LH middle outer rocker patch
rear quarter interrior pannels (black where 1/4 winow crank goes through)
RH (complete w/ light) & LH head light to grill housing
Jack
glove box door
94 ranger window regulators w/ crank handles
front seat belts (LH & RH)
steering wheel horn ring
rear bumper brackess & 68 rear bumper brackets
x1 rear window crank handle
front parking light housings
rear tail lights w/ red plastic insert
x1 rear tail light housing
head light bulb housings
front & rear bumper guards
vertical hood hinge support
rear licence plate light
brake petal support
brake petal arm
hood hinge w/ spring
gear shifter housing "cruse-o-matic"
wiper motor
raido
x2 LH shock towers (new)
gas tank w/ drain plug
steering column wireing harness
under dash harness w/ fuse box
under hood harness w/ voltage regulator
seat belts
c4 transmission cross member
6 CYL PARTS
valve cover
drive shaft w/ trans yoke
3 hubcaps "mustang spinner red/white/blue"
fomoco washer fluid bag
Idler arm w/bracket
x2 innder & outer tie rods
x2 center tie rod adjuster
center link
master cylinder single bowl
master cylinder push rod
x2 68 outer tie rods
pitman arm
68 double bowl master cylinder w/ push rod
raidor w/ c4 inlets
heater core
65 single bowl master cylinder
65 6 cyl front spindles w/ drums & w/ upper balljoint
:jaw:
