65 Rear End Question
There is so much conflicting info that I decided to take the backing plate off and look for a part number. Here is a pic of the backing plate. There is a FoMoCo stamped into it on one side and KH 70866 across from it, the KH I'm assuming is Kelsey Hayes.
I searched that KH number and found a Cougar site that had a couple. They state that they were for 1 3/4" brakes which I'm thinking is good news as I could just order the rebuild kit that comes with new drums for the 1 3/4" shoes. I can't seem to confirm anywhere that that's the backing plate for the rear on a 65 V8 Mustang though. Does anyone have a wheel & drum off at the moment (or one laying around) they can compare to.
In the pic you will see a red arrow pointing to the stamping on the backing plate. I think the depth of this stamping might be deeper than what is on a standard V8 car. Anyone know?
I just went out to the shop and looked at one of the sets I have on the shelf and they are stamped KH (yes, KH is Kelsey Hayes) 70866 and 70867, so it sounds like you still have the original backing plates.
Ok I think I may have this figured out. The drums are marked 1125B which research tell me are front brake drums, not rears. I think what happened is someone has, in the past, mounted front brake backing plates/drums to the rear axle. Since the backing plates are for 10" drums and the drums are for 2 1/2" shoes I think (hope) that I should be able to go to a junkyard and pick up a set of drums from a 1980-89 LTD or Lincoln Town car and use those.
At least that's what I'm hoping.:scratch: I read it on the internet so it must be true.
If the backing plates have the divots and holes for e-brake cables, they are not front plates. Not to mention, it appears that Realmongo has already ID'd the plates (at least one of them) for you.
Just Me Thinkin'
Gene
Sorry RealMongo, I missed that one somehow. Thank you a TON for checking that for me. Thanks to all others who tried to help here too, you guys are awesome! Now that I know I have the original backing plates I can proceed with the standard rebuild kit.
Cheers to all.:SN:
