65 stang Gas Level Help !
  • Thread starter Thread starter 408ponyman
  • Start date Start date Sep 2, 2008
408ponyman
12
  • Sep 2, 2008
I am going to replace the old one cuz the old one dont work no more . do i just replace it ?this is my first car by the way . Thnx for your time and help .
EDITl:
I have another question . I cant remove the pin frm the parking brake handle . any idea of how i can get it out ?
View attachment 305494​
66 Restomod
203
Raleigh, NC
Sep 2, 2008
  • Sep 2, 2008
This is how I did mine...
If you are replacing the fuel sender at the bottom of the gas tank, here's how I did mine.
First take the *new* unit and dip the brass float in a cup of water for at least 10-15 seconds to make sure there are no pinholes in it. If there are pinholes you will see bubbles, and the new unit will show Empty the next day. Then you will be doing this job again soon (ask me how I know)...
Second, I ran the car out of gas and filled it with about 2 gallons to get back home. Jacked up the front of the car to further push the remaining gas to the back of the tank. Put a drop bucket under the tank, but didn't end up needing it.
Third, disconnected the single electrical wire in middle of old sender, cut off old rubber line (buy a new one) with clamps. Then used a large pry bar with curved tip as a punch to back off the retaining ring around the old sender. Remove old sender.
Install new sender, using a new gasket. Use thick grease around the new gasket to help it stick to the bottom of the tank (ah, gravity...). Install sender so the tangs are lined up properly, not upside down, and when you whack the retaining ring around it, make sure you don't let the sender spin. The wire connector should be at 12:00 when done, on mine anyway, and the fuel line right under it.
Reattach new rubber fuel line and old electrical wire. Fill with gas and drive. HTH
408ponyman
12
  • Sep 2, 2008
Thnx for your help man . I read some were that you have to recalibrate something with the sender and the gauge .
66 Restomod
203
Raleigh, NC
Sep 2, 2008
  • Sep 2, 2008
A new sender should be calibrated already, so I didn't even check but some people do. Make sure your tank is the stock 16 gallon unit before you order the 16 gallon fuel sender though. That combination will matter.
408ponyman
12
  • Sep 2, 2008
ok ill make sure to do that . thnx for your help .
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Sep 2, 2008
  • Sep 2, 2008
Good pionts 66 restomod..
And dont smoke and dont use a Light bulb type trouble light!!!
One other point, If the gauge still dont work right replace the voltage regulator on the back of speedometer housing.
CJ Pony Parts - Ford Mustang Parts
part number HW-1565
408ponyman
12
  • Sep 3, 2008
I hope its the level . I have another Question also I want to remove the pin from the parking brake handle but it seems to be stuck any idea of how to remove it ?
408ponyman
12
  • Sep 5, 2008
New question added .
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
