I just finished my 5-lug conversion on my 65' coupe. This included lowering the front about 1.5", and lowering the rear about 1". I also had to have my original 6 cylinder driveshaft modified so that it would mate up to the new 8" rear-end. Got everything bolted together this weekend, pushed the car out of the garage, pressed the gas pedal, and noting. The engine revs but it doesn't go anywhere.
I pushed the car back in the garage checked that everything was connected, and tried again. Nothing. Jacked the car up, and re-adjusted the transmission selector. Everything looked spot on. Decided to test everything with the rear wheels off the ground. Tires spun perfectly driveshaft rotated everything looked good.
Lowered the car back to the ground. Pushed the car back out and nothing, wont go anywhere. Checked to see if the driveshaft was spinning its not. Does anyone have any ideas here what could be wrong?
