an 8" rear, properly prepped, will handle about 400hp, 350 with slicks at the dragstrip. another rear you might consider is the 8.8" out of an early 90's mustang gt. you would have to get rid of the stock suspension brackets, and weld on some leaf spring mounts, not hard to do, but you would have a rear that would handle about 95% of the hp that a 9" would, but it would be very close to the weight of the 8" rear, and you would have a large variety of components available for it. as to the Tbird IRS, i have considered it as a possibility, especially since i have seen it used under a 91 stang, but the subframe is large, heavy and bulky, and would require too much effort for the minimal, if any, gains you would get in ride or handling.
