Feel a little out of place here, not being in my II room..lol but Ineed some help/advice.
Anyhow, I'm swapping the crappy 6 cyl 4 lugger suspension for V8 5-lug stuff from my donor '71 Comet GT. Obviously the outter tie rod ends are too small for the larger hole in the Comet's drum brake assemblies. Do I need to swap out the entire steering linkage setup or find other outer tie rod ends? Also, the toe adjustment is quite a ways off (have yet to re-adjust w/new tie rods) but I don't see a whole lot of room for adjustment left in the tie rods. The Comet's steering linkage is quite a bit different from the Mustang's but I've toyed with the idea of seeing if it'll work. Has anyone tried? For a V8, do i need a different Centerlink? Am going to leave it manual steering for now but looking to upgrade to p/s later on.
Am also planning to swap the rear axle as i have the crappy integral in the '66. I assume that my shock plates will not work as with the U-bolts because the 8" looks larger in dia. The Comet's shock plates are for staggered shocks... no good for me.
Also thinking that I can convert the brake M/C from the Comet to the '66 and seen a few posts that talked a little of it. Am i thinking right? Any pointers?
I'm really unfamiliar with early mustangs. Never really had one. Had a '69 years back but never really did anything with it. Mosty 66-67 Fairlanes, Falcons, Mustang IIs, and Comets/Mavericks have been my cup of tea. Lots of similarities between the early Mustang and those. All help/advice appreciated.
Had to order it and I probably won't see it till Tuesday. Anyway, I'll have to hunt the second tie rod adapter. During today's work one got misplaced. Had them in the "spare parts" box and was going to put them in the toolbox in case you needed them and one is gone. I'll hunt tomorrow for it. Good luck
