66 Shuts off while driving
  • Thread starter Thread starter MustangPaul
  • Start date Start date Sep 9, 2007
MustangPaul
514
South East Louisiana
Sep 9, 2007
  • Sep 9, 2007
Hello all--
The GT did something interesting today--twice--while headed into
town. I was driving along and it just shut off, once at about 15 mph
and once at about 35 mph. No coughing/sputtering. Just like you had
turned the key off. I coasted for a minute, shifted into N and it
fired right back up. It wasn't particularly hot, for Louisiana,
either. All of my gauges seemed to be in line.
The battery is showing 12.4 across the posts and 14.2 at idle. I
thought my battery/alternator might be causing trouble, but the
battery seems to knock that thought. Haven't added anything new to
the car either. The ignition was replaced with a motocraft replacement about a year ago.
Ideas?
--P
dodgestang
1,360
Cecil County, MD
Sep 9, 2007
  • Sep 9, 2007
I would start by replacing the solenoid.
10secgoal
2,801
San Diego
Sep 9, 2007
  • Sep 9, 2007
Try the wire to the +. The little caps sometimes become loose and while wiggle around, kill the car, but start right up. Wiggle it by hand to see how tight it is. Either way I would take it off the coil, and pinch it a little with some pliers to make sure she's snug. I've seen this scenerio a few times.
MustangPaul
514
Sep 9, 2007
  • Sep 9, 2007
Thanks!
I'll try the + side tomorrow. That's an easy check. Anything else while I'm looking?
M
mustangman1974
463
  • Sep 10, 2007
Try replacing the wire from the coil to distributor mine had a damn short and did the same thing. thats an ignition problem. Also check the neutral starter safety switch. If those pigtails are rubbing on the exhaust manifold it will do the same thing.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Yesterday at 7:48 PM
AlexM556
A
Engine Car shutting off
  • coupe89
  • Aug 11, 2024
Fox 5.0 Mustang Tech Aug 19, 2024
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
C
Knocking after pull- went away?
  • Connormcclark
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2025
gkomo
