mcode said:can i install 1966 upper and lower control arms and strut rods from a 1966 mustang in a 1970 mustang. i know the lenghts are different
bnickel said:hmmmm, just wondering out loud here John. say you put the correct UCA shaft in a 65/66 upper arm and bolted it in a 69 would that then net you something along the lines of the GW uca? without the revised ball joint angle of course but then we could wedge cut the arm to compensate for that.
so would it work, ya think? i'm betting we would have to build a spacer like GW uses. i'm just wondering if the shorter arm would improve camber gain much like the GW arm is upposed to. any thoughts?
how much shorter is a 65/66 uca than a 67-70?
John,Well, I'm always up for checking into something new so I did some research
DarkBuddha said:Hey John, I excited to see these new arms... I'll add this thread to my webpage list tonight. BTW, if you run out of space on your server, consider using something like ImageShack (which is what I use these days). It's totally free and no bs annoying pop-ups or anything. One tip though... if you do decide to register, keep your original email and link because ImageShack doesn't have a log-in process and doesn't keep track of where the heck you put your stuff, so you've just got to make sure you always go in through your very own "MyImages" link. Bookmark it and it's no problem though (unless you clear your cookies and that's when you need your original activation email).
, me have no moneys
. my paint job pretty much drained my budget. i've been trying to hold off doing any suspension work until i have a ll the pieces i need to get it done. i have most of the replacement stuff to put it all back together but the stuff that's on there isn't all that old and has very little mileage so i'm ont in a hurry to work on the suspension yet. my main goal at the moment is weatherstripping, engine compartment harness and a new vinyl top. then i have a few interior pieces to get and i should be good to go for a while. have you ever bitten off more than you can chew at one time and had to spit some out so you could swallow? that's kind of how i feel right now with the stangGlad to do it.Opentracker said:Cool! I have a ton of photos that I have no room for. Thank you again for putting up a bunch of my stuff on your site.
John
tweet66 said:John, I was always under the impression that the upper arms on a 67 and later car were shorter since Ford moved the shock towers out while moving the lower mounts inward, necessitating the longer lower arm? the onluy way I could see using that later arms on an earlier (65-66) car would be to swap the towers as well. I have a set of 69 towers I was considering grafting into my other 66 coupe, when I get around to it![]()
