67 390 4speed Transmission Knock?
Steveo67390
I have an original 1967 390 V8 mustang with a 4 speed trans. While in the garage, engine running, I can increase the throttle then release it, I am hearing a single short knock sound on the driver side of the bell housing when the engine speed then decreases but does not occur at idle speed, somewhat above idle speed. Any ideas???
About the only thing that could make a noise would be the throw out bearing ,unless the clutch fork came off the pedestal or the pedestal retainer broke, Does the knock go away when the clutch is pushed and you bring up the RPMs?
So I fired it up today. Reved the engine and noise as usual was there on the engine decel. I pushed in and held in the clutch, reved, and no noise. Interesting part now, I slightly had my foot on the clutch pedal, pedal fully released, reved the engine, and the sound returned but I could feel a light jolt on the pedal as I heard the noise. Pushed and held the clutch, reved the engine, no sound. Repeated several times with clutch pedal held in, no noise. Again tested with no depressed clutch, and now the sound has gone away. Pulled the car in the garage, clutch works fine. What do you think, throwout bearing going bad? I have had several manual transmissions, never had a bearing go bad, only clutch plates that have worn out. But always have replaced all partsof course. Thanks.
It is possible a spring has broke in the clutch disk or pressure plate ,when the clutch is free of pressure no noise .A throw out bearing usually squeals . A 390 has a large inspection plate on the bottom of the bell housing ,put it up on jack stands and remove it just to see if the spring clip has come off the throw out arm where it clips to the pivot or one of the retaining clips has broke on the throw out bearing .If you can feel it in the pedal when you hear the knock something must have broke . You may find a piece of something in the bottom of the inspection pan .
