As posted in a different thread, I have lots of play in my steering. I found it to be the pitman are to ram cylinder connection. So rather than replace it with that piece ( I forget what it's called ) that replaces the ram cylinder with no re-alignment, I decided to just replace the drag link (cheaper used than 115 bucks) because when I do the granada swap, I will have to re-align anyways. I already have the idler arm for the manual steering. The pitman arm is different too isn't it ? Will say a 69 drag link work ? Reason I ask, is there is a 69 coupe in the junk yard right now that still has all this stuff. Would it fit ? Thanx in advance.
