67 Convertible Vin #??
  • Thread starter Thread starter brupert
  • Start date Start date Oct 26, 2005
brupert
  • Oct 26, 2005
I have just purchased a 67 convertible with a 302. The VIN number on the fender and the door plate decode it as a 67 coupe, Springtime Yellow, 6 cylinder?? is there any otther place I can verify the VIN #?? Is it possible to have a coupe code on a convertible?
Thanks......Bruce
J
JB66
565
New York
Oct 26, 2005
  • Oct 26, 2005
Not that I remember. Got a tag on the motor under the coil or off of the front of the fuel bowl on the carb? That may narrow the years down. Also look inside the rear quarter panels for Ford part numbers indicating they've been replaced. According to the shop manual the "official" number for title and registration purposes is stamped on the upper flange of the left front fender apron (not the fender itself).
67gt
38
  • Oct 26, 2005
on the top of the front fender on the drivers side, the buck tag (if you have one screwed into the same fender), and the build sheet (also if you have one). I found mine taped to the wire harness next to the steering column
Edbert
3,548
32
109
Austin TX
Oct 26, 2005
  • Oct 26, 2005
The roof can be cut off rather easily, but the windsheild and underside are completely different. Are your A-Pillars chrome on the outside? Is there a large steel plate bolted to the underside that crosses the driveshaft tunnel?
68 Coop
104
Mesquite, NV
Oct 27, 2005
  • Oct 27, 2005
Mine has it on the passenger side dash. When did they start this, 68??? Sorry, I'm still learning the history on these cars.
Soaring1
Banned
Jan 3, 2003
144
Texas
Oct 27, 2005
  • Oct 27, 2005
I believe the verts would have to have an reenforced rocker panel too. Look on the title to get the VIN then decode that.
Edbert
3,548
32
109
Austin TX
Oct 27, 2005
  • Oct 27, 2005
They started putting VINs on the firewall/windsheild area in '68.
If the VIN on the title is different than the VIN on the body (door tags mean very little) then you do not own this car. If the VIN on the body says 6cylinder coupe then that is what you own, even if a previous owner put a V8 in it and sawed off the roof. If you paid for a V8 convertible and can show intentional misinformation from the seller you may have recourse.
If you have a sawed-roof coupe then I suggest you stop driving it imediately, the car's chassis is too weak for use and WILL break in half, not a question of if but of when. Things can be done to prevent this, but they need to be done before critical damage is done if it is not already too late.
Things to look for in case it was an unsafe I6 to V8 swap are four lug wheels and a 7-inch rear differential.
Good luck and let us know what you find.
1320stang
4,329
23
89
Edmond, Oklahoma
Oct 27, 2005
  • Oct 27, 2005
Uh, guys? How about the door was replaced by a previous owner with one from a Springtime Yellow 6 cylinder coupe?
As everone has said, check the title vin against the door vin and look at the fender apron on the driver's side in front of the shock tower. There will be a notch in the fender about 3" long that uncover's the vin number.
Jester67
908
TN
Oct 27, 2005
  • Oct 27, 2005
Well since we are tossing out ideas here it might be a clip car and the coupe donated the front clip and the door.
Pakrat
3,843
Currently: NH Originally: Rhode Island (and all po
Oct 27, 2005
#10
  • Oct 27, 2005
  • #10
I thought he said the fender matched too? Considering this 67' has a 302 in it, any number of combinations could be possible here, heck, it could even really be partially a 68'. I can't offer any more advice on how to figure out what you actually have other than what has been said, but I can offer this for future reference.
When spending anymore than oh say $1,000 on a car, the proper order is you check the VIN first, THEN you actually buy the car if things check out. It's a subtle difference in procedure but it makes a world of difference.
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
M
How To Decode
  • Malcoll1
  • Mar 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
FoxChasis
F
L
SN95 Interior / Exterior Color Combinations - were some not possible?
  • lparsons42
  • Aug 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 2, 2025
Mustang5L5
G
CJ Pony Single Key Lock Set
  • GotMojo
  • May 12, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 11, 2025
Lockguy1967
L
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
