Ok, I've been working on this problem for about 1 month on and off and here's the story.
Recently got the car up and running and was bringing it to my house from the hobby shop where I work on it. After driving about 1 hour (it was running like a champ) it started running rough. I put it in neutral and the engine cut out. After pulling over it would not start for about 10 min and would run for about 10 more and then the same thing would occur.
Finally got it home and replaced just about everything I hadn't to that point. (fuel pump, cleaned the fuel filter, new coil, rechecked the idle mixture and float level on the carb and triple checked the timing) Nothing seemed to fix this problem. Now the car will idle and warm up fine in the driveway (it starts fine after warmed up) but after about 5 min of actual driving the engine will feel like it's missing and then cut out. I'll wait ten min and it will run again.
Here's the engine's particulars - stock 289 motor with a holley intake and 4 brl carb, stock mech fuel pump. It has aftermarket dual exhuast and a four speed manual transmission. Any help or ideas would be great as I'm just about out of them.
thanks
thanks
