67 gauges
xian67
I want the original gauges for the 67-67 but I can't find them anywhere. I only found some for the 65-66 model. And do the gauges come with the wiring?
The reason I want new ones is because the speedometer and the fuel gauge aren't accurate. When I would fill up the tank the fuel gauge would only move half way. I thought it was the float(floater?) that goes in the tank but that wasn't it. If I don't need new gauges what can it be?
Glazier Nolan has plenty of used ones.
The wiring is available new, separately.
The gauges were only so-so when new, and of course the sending units may be a problem, too. Current repro gas senders, for example, stink. They come new in the box with the wrong Ω rating. If your float sank you can get a new one, but if it's moving that's not the problem. GN tells me they are working with one of the repro manufacturers to fix the gas sender problem.
What is the wiring called for the gauges?
I just emailed [email protected] asking if they had the gauges.
