So I've searched a little.
Symptoms: Fuse blows after about ten minutes of driving. No turn signals. Right rear brake lamp out. Hazard flashers work.
I replaced a rear bulb that was bad. I've checked under dash for brake switch wiring problems: none.
I've read about the turn signal flasher. And to get a HD one. Will this cause my fuse to blow after ten minutes, but not right away?
Or the turn signal switch? It's doesn't turn off after a turn. It does stay up or down when activated.
I took the horn and steering wheel off to get a look at the turn switch. Can't see anything out of the ordinary.
