67 tie rod end taper size
  • Thread starter Thread starter 67rcks
  • Start date Start date May 8, 2012
67rcks
373
May 8, 2012
  • May 8, 2012
Hello can somebody advise on the size, in degrees or in/ft thank you
horse sence
8,309
233
Wile Coyote's stunt double
May 9, 2012
  • May 9, 2012
i believe fords are 7 degrees we are messing with that right now
trying to inlarge the 69 spindle arm for granada tie rods
67rcks
373
May 11, 2012
  • May 11, 2012
I found out (in the meanwhile) this should be 7.125°= 1.5" pre 12"
7° may work though
special equipment is needed to measure this angle precisely (not only micrometer)
2+2GT
3,333
10
79
Southeastern Pennsylvania
May 11, 2012
  • May 11, 2012
Wouldn't it be about a bazillion percent easier to just use a Granada outer tie rod end?
horse sence
8,309
233
May 11, 2012
  • May 11, 2012
its for a 66 mustang with the origional power stearing it requires
a specific bent tierod end it is granada ,speedway motors sells the
taper .the problem is the tie rod end is larger than even the 70 tie
rod end so the spindle arm must be re sized, the outer will work
on 67-70 with resizing
Staytuned stock bottem end build...
  • rednotch
  • Dec 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 13, 2025
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Friday at 10:17 AM
gkomo
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
Tips for WUE and ASE tuning
  • Mustang5L5
  • Oct 9, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 10, 2025
gkomo
Suspension Maximum Motorsports Tapered Bumpsteer Kit MMTR-2 - Replacement Spherical Rod Ends
  • AeroCoupe
  • Mar 30, 2025
Fox 5.0 Mustang Tech Mar 30, 2025
AeroCoupe
