67 trouble
  • Thread starter Thread starter g68
  • Start date Start date Aug 30, 2004
G
g68
  • Aug 30, 2004
I have a 67 coupe with a 289 bored .40 over (i was told that this had the displacement of a 302). now there is a loud popping noise whenever it accelerates. it only happens when it goes over 2000 rpm, even when its parked. a friend told me that something was wrong with the valve seating, and i would like to know how to fix it. the engine has an edelbrock cam hydraulic lifters and gtp 40 heads. Also would a 373 ratio on the rear end help with the lack of acceleration?
one2gamble
902
Monterey
Aug 30, 2004
  • Aug 30, 2004
you need to do better than "pop" , does it sound like metal hitting each other or is it a tick or is a pop. A pop would probably indicate that the engine is missing, this can be anything from a bad wire/plug to bad timing. The others could be valvetrain noise but they would normally exist even at idle. Another possibility is an exhaust leak that your just not hearing until its rev'd up.
G
g68
  • Aug 31, 2004
it sound like its back firing. i was told that it could be valve seating but i dont konw how to fix it less know what exactly is wrong.
65fastback2+2
1,229
Louisville, KY
Aug 31, 2004
  • Aug 31, 2004
or it could be as simple as carb mixture
H
horseycar
Ft. Worth, Texas
Sep 1, 2004
  • Sep 1, 2004
I also have a bored over 289 in a 1967 coupe. Mine would pop 4 or 5 times when I would hammer the accelerator. The problem wound up being bad timing and bad plug wires.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Sep 1, 2004
  • Sep 1, 2004
If it pops when you let off the gas, then it's probably an exhaust leak. If it pops when your on the gas, then your timing or carb is the most likely culprit. Make sure all of your vaccuum hoses are connected correctly also, especially the advance from the distributor.
Thinking of looking at this 67 coupe. Looking for some opinions.
  • billison
  • Aug 11, 2024
1965 - 1973 Classic Mustangs -General/Talk- Aug 28, 2024
89ripper
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
M
Vacuum or Timing issue
  • Moistbois
  • Dec 20, 2021
Classic Mustang Specific Tech Feb 10, 2022
General karthief
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
20K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
Engine Rocker Noise after Aluminum heads and 1 piece CM Pushrods
  • 79pace
  • Apr 12, 2022
4K
Fox 5.0 Mustang Tech Apr 19, 2022
Monkeybutt2000
M
