68 temp gauge-2 questions
  • Thread starter Thread starter Purple
  • Start date Start date Aug 25, 2008
P
Purple
  • Aug 25, 2008
My temp gauge starts out all the way on the left in the cold area, over the course of about 15 minutes it will make it to the middle. By the time I am driving about 1/2 hour it moves all the way to the hot side. The car runs great, and I verified the actual temp with a Fluke digital thermo that the highest reading I got at the top radiator hose was 193 degrees. QUESTION ONE, is there any way to adjust the needle reading? Could you put a resistor in the line to adjust the actaul reading back to the gauge? TWO, I can't find a replacement gauge anywhere, like CJ etc. Anyone know where and if they are available?
R
RedGTvert
3,129
Wellington, FL
Aug 25, 2008
  • Aug 25, 2008
Sounds like one of those great aftermarket or reproduction sensors. They are terribly off. I had the same problem, found an NOS one, and temps are reading as expected.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Aug 29, 2008
  • Aug 29, 2008
That, or just a bad sending unit.
P
Purple
  • Aug 31, 2008
I bought the sending unit from AutoZone and it looked just like the one I took out. My car did something yesterday that it hasn't done before though! When I got back from a two hour ride, I noticed I had steam coming from the bottom of the catch can. After letting it cool down, I checked the water level, and it was below the fins in the top of the radiator. It took a half gallon of coolant to bring it above the fins. My cap is rated for 13lbs. Is it possible that it is bad, or should I be running a higher rated cap? I ran it after I filled it with the cap off and the heater on to check for air, but I never saw anything. I waited for the thermostat to open, and still nothing strange. I was thinking head gaskets, but it runs great and I never see anything unusual out of the tail pipes.
S-Car-Go
332
San Jose, CA
Sep 1, 2008
  • Sep 1, 2008
I can't offer a solution, but I will say my AutoZone temp sensor reads exactly like what you are describing. I've never had a problem thogh. My gauge is way off once it gets warm.
I had a a high flow T-Stat that read in the middle. When I measured the temp at the water neck with a Fluke 52, it was 110*. This was after running it for 45 minutes in my driveway. There was waaaay to much bypass on the T-Stat. Now I just let it run on the warm side with a standard flow T-Stat.
M
mustangman1974
463
  • Sep 1, 2008
u need to check the voltage constant regulator on the back of your instrument panel. I think its supposed to be 12 volts, but I am not sure. I replaced mine about 10 years ago when I was having problems with my guages.
P
Purple
  • Sep 2, 2008
I thought that if my oil pressure and voltage gauges seem to be reading normally that it would not be the CVR. Some other questions I have read say it could be a bad head gasket, but I checked for coolant in my oil and oil in my coolant......nothing. No white smoke while driving, no air bubbles in the radiator while it runs with the cap off. I guess I should just buy a cheap temp gauge and see what it reads on something other that the old gauge.
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
Forced Induction Vortech v3 low boost (like 2 psi)
  • 92Rustang
  • Jul 29, 2024
3K
Fox 5.0 Mustang Tech Oct 2, 2025
Mindseye007
  • dan50
  • Jul 18, 2026
dan50
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
