6x8s speakers bass cuts out over volume 5
If you run a speaker with lower impedance then the amp can handle you'll have problems with the sound. If you run a speaker with a higher impedance then the amplifier you'll just get less output. The solution would be ditch the mach 460 amps and run an aftermarket setup, or find some 8 ohm speakers.
