70 Radiator in 65 Mustang
I have an opportunity to pick up a new 70 Mustang Becool radiator and dual 11" fan unit at a good price. I am aware I have to enlarge the opening in the rad support and remove the battery so that it will fit. My question is what brackets do I need to use and which work best to mount the rad and dual 11" fans in the 65? Here is a quick link which shows all the bracket choices for the radiator and fans.
Frank
http://www.jegs.com/webapp/wcs/stor...fier=&categoryId=24297&parentCategoryId=11473
I found the pic below and I cannot seem to find those fan brackets.
are you sure the inlet and outlet will work with your motor?
mine are on the oposite sides,
inlet on top , pass side
outlet on bottom, driver side.
If the hoses are correct , id do what ever you have to do to get it to bolt in, its a nice set up. Shouldnt be too dificult.
Mine is just like yours, that pic is just for reference (and not a good one at that). Here is a pic of the actual unit, it looks pretty big. BTW, I found the brackets in a kit if anybody else is thinking of doing the same thing. Pricey but they mount it right.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=BCI-72045&N=400001+115&autoview=sku
I found the 70 Mustang Becool on Ebay brand new for $300 shipped, and the Spal dual fan unit for $180 shipped. Much easier to swallow than the $970 unit from Rons Radiator shop.
