70mm TB
  • Thread starter Thread starter Roland69
  • Start date Start date May 23, 2007
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 23, 2007
  • May 23, 2007
would a 70MM TB help my stock emgine any or is that too big. I will be buying the egr plate to match but just wanted to know if I would gain any or if I could go to big. Would a 65MM be better or is the 70 fine
BigHairyMonkey
411
Houston (Bellaire) TX
May 23, 2007
  • May 23, 2007
i would def go 65mm. that is more than enough for a stock to mild combo. Also, it really wont make to much of a difference if you still run a stock MAF.
bobbyd
312
San Antonio/Los Angeles
May 24, 2007
  • May 24, 2007
yea i also would like to know this.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
May 24, 2007
  • May 24, 2007
I run a 70MM TB on mine. I also have a GT-40 intake w/ a ported lower. No problems or loss of power here.
R
RioRed4v
24
Las Vegas
May 24, 2007
  • May 24, 2007
if you have a 65mm, i would just use that one.. otherwise, i would just match the size of the intake opening.
i run a 70mm on my car (intake opening is a little larger.. probably like 73mm) and runs and drives fine.
Maryland Stang
1,656
30
39
Greenville, NC
May 24, 2007
  • May 24, 2007
RioRed4v touched on what I was going to point out. The EGR spacer and TB size need to match or be smaller than the opening on your intake manifold. I don't remember the exact size of the factory intake opening but I think it's right around 60mm. You'll need to enlarge the intake opening to 70mm by whatever means you have in order not to cost horsepower with your bigger TB.
ShortThrow50
923
Pa
May 24, 2007
  • May 24, 2007
waste of money if you ask me if your engine is completely stock. Get the tb and egr after youve changed out ur upper, lower, and maf.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 24, 2007
  • May 24, 2007
I am still S/D.....
jcw88
Never played w/ it before so i'm still a virgin!
Mar 20, 2007
53
fernandina, fl
May 24, 2007
  • May 24, 2007
i have a 70mm tb w/ a few other mods and i have been told that its a waste but i see a difference matched w/ my c&l maf and tf upper and lower..
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 24, 2007
#10
  • May 24, 2007
  • #10
anyone know the stock upper intake size...is it 60mm
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
May 25, 2007
#11
  • May 25, 2007
  • #11
for some reason i thought it was 55mm stock, 60mm for cobra, but i could be (probably am) worng.
V
v8only
2,378
22
49
May 25, 2007
#12
  • May 25, 2007
  • #12
absolutely NO point in jumping up a size in t/b until you have BOTH heads and intake.
FYI, I've got gt40p heads and a ported explorer intake, and a 65mm t/b is perfectly matched.
a 70 is WAY too much for a stock engine. while you won't likely loose power, it'll wack out your throttle response.
until you start packing on the mods, spend the money elsewhere.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
May 25, 2007
#13
  • May 25, 2007
  • #13
Didn't hurt my throttle responce.... There's a reason back in the day guys port matched the stock upper for a 75MM tb.
Sicarius428
2,085
May 25, 2007
#14
  • May 25, 2007
  • #14
The intake will still be the bottleneck. Put your money towards a new intake first.
Kevin
BigDanTheMan
63
San Francisco, CA
May 25, 2007
#15
  • May 25, 2007
  • #15
i wish that i had saved up money for a new manifold that doesn't require a spacer than just running out and getting a tb and a spacer. look at the cobra intake, bbk ssi or others that have a "built in" spacer. in hindsight it'll make more sense than committing to the egr spacer when i'm sure that you'll eventually want to move up to a better engineered intake manifold.
as for the 65vs70mm get the 70 if you have other bigger upgrades planned, otherwise the 65 will be a better application.
R
RioRed4v
24
Las Vegas
May 25, 2007
#16
  • May 25, 2007
  • #16
i wouldnt go as far as saying ssi or cobra intakes are better than others just because they have a built in spacer.. its a nice feature, but definitely isnt something to pick an intake out by, especially when you can get egr spacers/deletes for pretty cheap.
Aftrbrnr
Whitey cashier gave me the wrong change at the sup
1,183
15
89
Canaduh
May 25, 2007
#17
  • May 25, 2007
  • #17
This is what "The Mustang Shop" in Calgary, Alberta, Canada told me:
As for the throttle bodies, NA motors perform the best when using a 65MM and most forced induction motors perform best with the 70. If you choose a 70MM for your NA motor, your bottom end will suffer a bit.
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
5K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
