For Sale Mustang SVT cobra 600hp built turbo
Bullitt4691
14
1999 Mustang Cobra. located in Long Beach, CA.asking 15500.
Engine:
-4.6L 284ci 32v 10.0cr
-Teksid aluminum block .30 over ( bored to match pistons, block was perfect) Decked, Honed
-SVT Cobra forged crank - polished
-SCAT forged 4340 H beam rods
-CP dished forged pistons, coated skirts
-King bearings
-Rings gapped for boost
-Internally balanced
-ARP main studs, rod bolts, crank bolt, cam bolt, oil pan studs, head studs etc
-New ford OEM oil pan pick up and high volume pump
-New gaskets
-2001 Cobra C heads. stage 2 port and polish..5 angle valve job with bowl cleanup
-new oem guides, rockers, valve seats,lash adjusters
-Twin blade polished throttle body
-50lb fuel injectors, good o rings.. flow tested
-Morso coolant overflow set up.. MMR cooling mods
Drivetrain
-FRPP billet flywheel
-Spec stage 2+plus clutch (rated for 650hp)
-Rebuilt T-3650 transmisson with upgraded 1-2 shift forks and mach-1 OD
-Steeda tri-ax shifter.. stock knob
-18x9 and 18x10 staggered bullitt rims
-Nitto 255 fronts and 295 in the rear
Turbocharger
-Forward facing headers
-Precision 70mm turbo
-Downpipe preweld for wideband
-Upstream o2 sensors
-Aluminum intercooler
-Aluminum from throttle body to intercooler
-Turbo support bracket
-38mm wastegate
-50mm blow off valve
-4ply/5mm silicone couplers
-T bolt clamps
Exhaust
-OEM pig ire we toon headers (best for turbo systems-high heat applications
-Custom turbo hot side pipping.
-Custom 3inch y pipe
-Pypes stainless IRS race bullet catback
Fuel
-63lb injectors
- FRPP fuel rail kit
-8 black feed line from tank to filter
-2004 cobra terminator baffled fuel tank
-2004 cobra terminator duel fuel pump hat. duel ford GT fuel pumps
-Kenne Bell boost-a-pump
Interior
Tan interior
A pillar double gauge pod
Autometer Fuel gauge
Autometer boost gauge
5% tint
Aftermarket audio system
Suspension/chassis
-upgraded cast and camber plates
-QA1 tubular k members and a arms
-front bump steer kit
-H&R lowering springs
-Eibach shocks and struts
-rebuilt IRS with 3.27 gears
-upgraded IRS bushings
-Mach 1 front splitter
-Wing included with car but currently not attached
