71 Disc Brakes On 69 W Druns
You have to use the disk brake spindles ,drum spindles are drums only .The disk spindles for the 71 will work but you will have to change the tie rod ends to match the 71 as they are larger eyelets . 70 -73 disk spindles are a great up grade ,they are stronger than the 68 -69.
