73 conversion
  • Thread starter Thread starter jp73
  • Start date Start date Apr 12, 2008
J
jp73
  • Apr 12, 2008
i am considering replacing the tired 302 in my 73 convertible does anyone have any pros or cons for installing a 4.6l the donor car was free so that is a plus
bnickel
5,640
lubbock, texas
Apr 12, 2008
  • Apr 12, 2008
i've been considering something like this for a car for my daughter when she's old enough to drive, but haven't researched it much yet. the engine bay in the 71-73 stangs was made to accept the boss 429 and the sohc motor is about the same width as the boss '9, maybe a little narrower. i'm thinking it should fit but you'll have to do some modifications to both the car and the engine more than likely. i know you'll need custom mounts and probably a modified oil pan and you may also need to modify the crossmember on the car a little. then again it may drop right in with custom mounts but i wouldn't count on it. my only other concern would be the exhaust manifolds on the engine and whether or not they will clear the shock towers.
J
jp73
  • Apr 12, 2008
iv checked left and right and for front to back i think i can get it in mostly concerned if trouble is worth it or should i rebuild the 302 the donor car is 92 crown vic checking if brakes would work also main concern is for the money would 302 be just as good or would fuel injection and aod trans. be worth the trouble
bnickel
5,640
lubbock, texas
Apr 12, 2008
  • Apr 12, 2008
i'm not sure if the 4.6 would offer any real advantage over a 302 with or without efi or not. i was considering because by the time my daughter is able to drive (at least another 7 years) the 4.6 parts will probably be more plentiful than pushrod parts.
i know you can use CV brakes front and rear but you'll need to buy one of the spacer kits for the rear brakes on ebay and make your own brackets and such for the fronts but i have seen it done.
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
K
Introduction
  • kleach
  • Feb 10, 2026
  • The Welcome Wagon
The Welcome Wagon Feb 10, 2026
gkomo
C
Bored with my 73
  • Curtis Harper
  • Apr 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 23, 2026
RaggedGT
