I'm needing advise on a motor build for my 73 Mach 1 resto. I have been given a build sheet for a 408 Stroker Motor using a Ford Racing Boss 351 Block. Here is what I was quoted (i would like any advice on this):
Scat forged steel crank, Scat forged steel H beam rods with ARP bolts, Mahle forged pistons with floating wrist pins, Hydraulic roller camshaft (Camshaft lift: .594 in. intake / .618 in. exhaust), Custom 3/8 push rods, Ford performance aluminum "Z" cylinder heads (2.02 in. intake / 1.60 in. exhaust valves), PAC 1219X ovate beehive valve springs, Roller rocker arms: 1.654:1 ratio, SFI-approved Harmonic balancer, Victor Jr. intake manifold, Steel oil pan with windage tray and scraper, Holly Sniper, MSD 6 AL, MSD distributor #85840, SFI Flywheel, Zoom Clutch, TKO 500 Tansmission.
Thanks for any thoughts!
