76mm C&L MAF
Search for MAF on here and you'll hear all sorts of horror stories about them, you'll also see a slew of people that use them with no problems. I ended up going with a 70mm Pro-M and have had no problems!
Yea i would do some serious research before you go ahead an order a C&L...like flavadave said, some people run them with no problems....some people have horrible rich conditions and raging surging idle syndrome. I think pro-m...or professional mass air systems (PMAS) are the best meters out there. Im running there 75mm unit with no problems. Check out their site before you settle on a C&L. good luck man
I've got one on my less-than-common setup (see sig) and it runs great. I'm running it with 30lb/hr injectors. I'll probably end up getting a TwEECer, and a bigger fuel pump, the FP I have now is strugglin' to keep up with the 357C and
30lb injectors. I've done a bunch of work since I built the EFI setup, I'm working on an intake now with 2" runners and a large upper plentum, with (when I find one) a cobra twin throttle body. I've got a single 70mm TB on it now, that's going on my mom's '01 CV P71, when I finish up my intake and throw in my Lunati cam.
I have a 76mm and it went in the pooper. My low end dissapeared and my idles was all over the place. Didnt have the cash to replace it so I just pulled the sensor out of a stock 19# unit and dropped it into the C&L housing...PRESTO! I am NOT impressed with C&L electronics...although I dont mind using their housings hehe :D
I run the C&L 76mm and I did have a few problems with it when I first installed it.
Rotating the housing helped alot as did resetting the idle and TPS.
Runs great now. I think the C&L is a great piece for the $$ and for the person who isnt going to heavily moddify their stang.
Now if/when I go to a turbo setup I will be installing a PMAS or equivalent MAF that will allow for more precise tuning and adjustment.
But for a mostly stock engine the C&L is perfect.
