urban96 bubb rubb says:"woo woooooo" Founding Member Sep 24, 2002 3,464 1 69 Syracuse, NY Jun 9, 2005 #1 Jun 9, 2005 #1 same as ours or different?
94-302-vert Active Member Aug 16, 2004 1,947 2 36 NE CT Jun 9, 2005 #2 Jun 9, 2005 #2 Same FRPP alum d/s. So I vote same.
W wytstang Mustang Master Mar 14, 2004 4,988 4 78 Summerville,SC missing South Fl. weather :( Jun 9, 2005 #3 Jun 9, 2005 #3 94-302-vert said: Same FRPP alum d/s. So I vote same. Click to expand... +1, unless the FRPP uses a longer yolk (I think that's what it's called) that slides in the tailshaft to make up the different lenghts between the two.
blksn955.o Founding Member Mar 15, 2002 3,263 0 66 st.louis mo 314 Jun 9, 2005 #4 Jun 9, 2005 #4 It will work but you will need a spacer, the -93 were shorter and when using the FRPP alum. shaft you have to run a spacer.
