8.8 q's
  • Thread starter Thread starter At1Maverick69
  • Start date Start date Nov 24, 2004
First Prev 2 of 2
HardmanGT
500
Thomaston, CT
Nov 25, 2004
#21
  • Nov 25, 2004
  • #21
Mavrick said:
hllon4whls is right.. that is not good at all. Even my old rearend, which i found to have 0 friction material left on the clutches, both wheels would spin the same way when you turn them manually. Same goes for my freshly built rear..
If your tires spin opposite directions, i would assume it's got some issues. Chevy rear ends work like that though, wheels spin opposite as apposed to the same direction. Obviously a problem
Nope, the differential is working just fine and is supposed to spin in opposite directions in normal free-wheeling operation. The only time the wheels spin in the same direction is when the clutches are engaged. They only engage when they see a load at the wheel. There is no load when you have the tires off the ground
The only exception to this is whe the clutches are shimmed tighter than facory spec OR an F series pickup spring has been installed in place of the factory spring to increase clutch preload.
At1Maverick69
220
San Leandro, Cali
Nov 25, 2004
#22
  • Nov 25, 2004
  • #22
maverick0716 said:
Don't forget you'll need a different master cylinder for that rear disc setup.
oh yeah, I know, thanks! that and a prop valve- and where can I get the right parking brake cable? anybody know?
At1Maverick69
220
San Leandro, Cali
Nov 25, 2004
#23
  • Nov 25, 2004
  • #23
This is really getting confusing, but I just though about this, how is it that when I spin the SVO rear I have on jackstands, it spins the same way, does that mean its been shimmed? same goes with my limited slip on my 69 coupe- I know it's not at all the same design, but i though it would do the same..
At1Maverick69
220
San Leandro, Cali
Nov 25, 2004
#24
  • Nov 25, 2004
  • #24
squeeeg said:
You rprob have to rebuild the traction lock. It is very easy to do. As soon as you get the s clip out and the axels, the rest just falls apart almost. Goes together almost as easy
If I go towards rebuilding it, Im assuming I just yank on that S clip, right? then the spider gears, u just spin out, right? I have a chilton- just not too much info in there though, thanks guys!
and OHHH!!! HAPPY THANKSGIVING!!!!!!!!!!
maverick0716
3,924
Chilliwack, BC, Canada
Nov 25, 2004
#25
  • Nov 25, 2004
  • #25
Any stock 5.0L GT/LX that I've seen with a working Trak-Lok unit had both tires spinning the same direction. Any unit not working I've seen them spin opposite directions. It's as simple as that.
maverick0716
3,924
Nov 25, 2004
#26
  • Nov 25, 2004
  • #26
The way the limited slip differentials work is that when you're going in a straight line the "clutches" aren't slipping, so they lock both wheels in the same direction. When you turn a corner though, one wheel HAS to go a different speed (travel more distance) than the other.....when that happens the clutches slip to allow the other tire to travel faster.
P.S. - You will notice on full locking differentials that when they turn a corner the inside tire will "skip" along because it's travelling the same speed as the outer tire.
squeeeg
1,905
Michigan
Nov 25, 2004
#27
  • Nov 25, 2004
  • #27
First you have to take off the drums and push in the axle so you can get the c clips off then slide the axle out so it will clear the s spring which is in there pretty tight. You also have to remove the pin which I think is an 8mm bolt. Then you can remove the s spring.
First Prev 2 of 2
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
Granada Front Disc, 9” Drum Rear, 86 Bronco II MC, and Manual Brakes - Pedal Slack
  • AeroCoupe
  • Jul 8, 2023
2K
1965 - 1973 Classic Mustangs -General/Talk- Jul 14, 2023
AeroCoupe
R
Axle Research
  • rice_man
  • Mar 16, 2023
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 27, 2023
General karthief
