8.8 questions
  • Thread starter Thread starter 89StangChris
  • Start date Start date Oct 22, 2006
89StangChris
  • Oct 22, 2006
I have an 8.8 housing that I will be installing in my 1989 coupe. I am considering mini tubs for larger wheels. However, I have read about taking an inch or so off of the axle tubes and installing appropriate axles. What I want to know, is, what is the maximum I can narrow my rear end WITHOUT installing mini tubs or cutting up the wheel wells, and what size drag radials can I then install? Also, an S Box from Wild Rides Race Cars will be in place on the car. IF AT ALL POSSIBLE, I do not want to do any cutting on the body. The rim size will be 15 inch, c clip eliminators, and preferably, disk brakes. This will be a 10 to 9 secibd car, so daily driveability is not a problem.
Any advice on this matter is greatly appreciated. THANKS!
M
MatthewP
355
Calgary, Alberta
Oct 22, 2006
  • Oct 22, 2006
With a standard fox3 width rear end in my 90 coupe, Steeda weight jacker (adjustable spring perch) lower control arms, and 28x10.5 ET Drags on 15x9 drag lights, I had to do some minor fender lip rolling AND a small amount of relief with a hammer on the inner fender sheet metal to make it all work. I have also run 28x12.5 ET Streets, which are virtually the same as the ET Drags, but have a slightly wider section width.
Based on the fact that I needed the hammer on both the inboard and outboard portions of the fenders with a standard width housing, I would say that the maximum you can narrow the rear end without installing mini tubs or cutting anything is zero.
Good luck.
-Matthew
89StangChris
  • Oct 23, 2006
Thanks for the information. I guess there goes the back seat and trunk hinges... Here comes the heart attack when I contact the local chassis shop.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
C
Help identifying 8.8
  • Caden_H
  • Jun 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 12, 2025
limp
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
  • dan50
  • Jul 18, 2026
dan50
