Yes I have.
The drive shaft from the fox would need to be lengthened. IIRC the Fox is about 46", and depending on transmission/pinion yoke, the Mustang will be about 50". So you take it to a shop with the measurements, and they weld in a new tube. Cheap and easy.
There is a write up on one of the 8.8" installs I've done on the website in the signature below.
Pretty easy, and has been done so many times, that there is enough information to fill up a Wiki site.
Do some searching, and you'll find some really cool installs from different guys here, and on other Mustang web forums. There are also other 8.8" options you should look at as well, like the Explorer swap.
Good luck,
