  • SN95 4.6L Mustang Tech
8 ERROR CODES??? HELP ME NOW!!!
  • Thread starter Thread starter MoNsTaMaCk24
  • Start date Start date Jul 18, 2004
1 of 2 Next Last
M
MoNsTaMaCk24
742
Shippensburg, PA
Jul 18, 2004
  • Jul 18, 2004
My car threw 8 error codes... But actually only 4 but they were thrown 2 times... The guy at Auto Zone was like what the HE!! You doggin this... Thats when I kicked him behind the head and smashed his face on the concrete and nicely asked him to tell me the codes... HA! Nah but he gave them to me and I need help to get this annoying light off.. I put two new rear Mils on and 2 new O2's... I put a used O2 on the driver front yesterday also... Should I put a newer O2 on the passenger side now too??? I have one... And do I need a new EGR Valve and Sensor and DPFE Sensor??? This is a pain... I cant pass emissions til these things are off and gone for good!!!
P1443
P0155
P0402
P1151
M
MoNsTaMaCk24
742
Shippensburg, PA
Jul 18, 2004
  • Jul 18, 2004
P1443- Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault.
P0155 Upstream Heated Oxygen Sensor circuit fault - Bank No. 2.
P0402 EGR Flow Excessive at Idle.
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2.
Thats what i found out they mean... Now turning them off is a problem!!!!
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 18, 2004
  • Jul 18, 2004
P1443, you need a new purge valve. i believe its only available from a dealer.
P0155, you need a new O2 sensor on the front drivers side.
P0402, propably a new EGR sensor
P1151, will dissapear when you fix P0155
M
MoNsTaMaCk24
742
Shippensburg, PA
Jul 18, 2004
  • Jul 18, 2004
Is he right??? I replaced the front o2 driver with a o2 that had only like 15,000 miles... Sure there isnt a fuse or something for these??? Maybe it blew....
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 18, 2004
  • Jul 18, 2004
everytime that ive had a car throw a O2 sensor code it has required a new O2 sensor. they arent really fixable and using used ones isnt the greatest thing in the world because they can be fouled fairly easy.
M
MoNsTaMaCk24
742
Shippensburg, PA
Jul 18, 2004
  • Jul 18, 2004
Yeah I have another front one here... I will try it... And maybe flip the other front one and see what that does... I ordered 2 front and 2 rear from a guy and the 2 rear worked great! I hope the other works... If it doesnt and the flip dont I know it is something else wrong... Emmissions are so expensive to pass... I heard a lot of talk that those flow sensors arent the egr sensor but a DPFE sensor... Silver plate above the driver side head near the firewall... Its suppose to control a lot of the flow... My car has over 100,000 miles so electrical would be going bad....ERRRRRRR
M
MoNsTaMaCk24
742
Shippensburg, PA
Jul 18, 2004
  • Jul 18, 2004
Boy not everyone jump on this one... Jeez....
M
MoNsTaMaCk24
742
Shippensburg, PA
Jul 18, 2004
  • Jul 18, 2004
Well I drove it tonight I put in a new o2 sensor... Drove for like 20 miles or so... No check engine light... I turned it off... turned it back on... I pull in my driveway and as soon as I put it in PARK... THERE IS MY FRIEND!!! Mr. Bright Yellow Light!!! So I am thinking has to do with EGR now... Ill try the Purge valve first... then... EGR Sensor... Then DPFE sensor... If they dont work new EGR.... I think I may have solved the O2 thing now...
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 18, 2004
  • Jul 18, 2004
get the codes pulled again. if its an O2 sensor code you might have to break down and buy new O2 sensors. the EVAP sensor is a given you have to buy that or else the code will throw constantly.
M
MoNsTaMaCk24
742
Shippensburg, PA
Jul 18, 2004
#10
  • Jul 18, 2004
  • #10
EVAP sensor???? thats wat it is?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 18, 2004
#11
  • Jul 18, 2004
  • #11
its actualy the Evaporative System Purge Control Valve. thats the only way to fix that P1443 code. and i believe its dealer only.
M
MoNsTaMaCk24
742
Shippensburg, PA
Jul 18, 2004
#12
  • Jul 18, 2004
  • #12
that isnt PCV valve is it??? I replaced mine....
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 18, 2004
#13
  • Jul 18, 2004
  • #13
no, PCV and EVAP are totally different. PCV just vents into your intake. the EVAP vents the air/gas from the gastank into the charcoal canister to keep it from going into the atmosphere.
M
MoNsTaMaCk24
742
Shippensburg, PA
Jul 19, 2004
#14
  • Jul 19, 2004
  • #14
Where is the EVAP sensor located???
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 19, 2004
#15
  • Jul 19, 2004
  • #15
i believe its near the firewall on the passenger side of center. when you get the new one just look around that area and find where it is. there should be an electrical connecter and 2 vacuums lines on it.
Carl
613
Johnson City, TN
Jul 19, 2004
#16
  • Jul 19, 2004
  • #16
The Purge Control Valve is in the passenger side fenderwell. Jack up the front passenger side of your car, take off your wheel and remove the black plastic inner fender liner. The valve is in the upper left corner. It's like a big black bowl with a lid on it. It's got an electrical connector and some vacuum lines going into it. Make sure not to get the lines backwards after you swap it.
M
MoNsTaMaCk24
742
Shippensburg, PA
Jul 19, 2004
#17
  • Jul 19, 2004
  • #17
Ok I Bought the EVAP thing... FORD place pisses me off... They know nothing there.... What else I need instead of 02 sensor??? DPFE sensor egr sensor or egr valve???
Turbo92PGT
746
Auburn Washington
Jul 19, 2004
#18
  • Jul 19, 2004
  • #18
I've got that stupid p1443 code. Its bs. can anyone take pics of exactly what this thing is? I know what a charcoal canister is. But how do I know if its the purge or some sensor or whatever? Something is for sure wrong because its thrown the code the last 3 or 4 days in a row. I have a code reader and keep it in my car for this code throwing baby. Also what problems can come from now replacing the sensor or whatever it is? Hesitation.... etc?
M
MoNsTaMaCk24
742
Shippensburg, PA
Jul 19, 2004
#19
  • Jul 19, 2004
  • #19
Cost me 61.94 it isnt cheap.... AND I still need to buy more.... These mustangs are a joke!!! ERRRRRRRRR!!!! Whatother sensor I need if I fix this and it dont fix the light Ill be so mad!!!
Carl
613
Johnson City, TN
Jul 19, 2004
#20
  • Jul 19, 2004
  • #20
Before you throw anymore money at it, check your vacuum lines. It's weird that you got so many codes at once. You might just have a bad vacuum leak. Cuz your EGR and EVAP system work off of vacuum. Plus if you have a bad vacuum leak it could cause you to run lean and that would set off your check engine for a lean or o2 sensor fault. Check all your lines under the hood, and check the fitting on the Purge valve in the passenger side inner fender.
1 of 2 Next Last
J
Switched to e85 on the 3v and now it won't run right.
  • jcowdough
  • Aug 24, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 24, 2025
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
R
93 LX 2.3 Trouble codes 53, 85, 21 help
  • Rickshaw302
  • Apr 15, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 18, 2025
AeroCoupe
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
