8 inch rear questions
shotsy
233
Oklahoma City
I've broke down and bought a powertrax locker to go in my 8 inch rear, and I have a few questions.
1. How much gear oil does the 8" rear require?
2. With the powertrax locker (no clutches) do I need to run a gear oil with a friction addative?
3. I've got a new chunk gasket and figured while it was off I'd change the pinion seal. How hard is it to swap out the pinion seal, and will I have to worry about setting the gear lash if I take the pinion out to swap the seal?
Thanks for your help guys, I cant wait to lay down some rubber from both tires!!
I've got the powertrax no slip in my 8" right now. It's pretty smooth except in tight parking lot turns - it ratchets. As for additives, you don't need any, just buy a good synthetic gear oil. Not sure how much I used.
