8 qt. milodon oil pan - fitment warning!
enferno
418
dropped my engine in recently, 289 w/ c4.
i threw in a 8 quart deep-sump milodon oil pan.
after getting everything hooked up, i turned the key and there was a bad knock.
the balancing weight on the flywheel was hitting the spacer plate between the block and the tranny. this was caused by the oil pan. the back lip of it pushed the spacer plate into the bell housing area just enough to strike the balancing weight. i had to drop the tranny and grind off about 1/16th of an inch of the pan and replace the spacer plate in order to get everything to fit propperly.
just thought i'd give anyone that has/is planning to use this pan a heads up.
66forfun said:
hows the ground clearance?
it sits just barley lower than the frame rails do. i'm really cautious going over speed bumps/bumps in the road as i'm not entirely sure how low my car will go when it's bumped.
no problems so far though
