Fox 81 mustang steering wheel bolts?
None direct fit. You'll need an adapter hub. I'm not even sure a correct adapter hub exists for 79-83
Stock setup is a single bolt behind the horn pad. Once you remove the bolt, use an appropriate steering wheel puller to remove the wheel. After that, you'll need a hub adapter for a 79-83 Mustang. The later 84-89 adapter won't work on the earlier hub and many aftermarket hubs incorrectly state 79-04.
