83 GT door hinges
  • Thread starter Thread starter ventura
  • Start date Start date Feb 19, 2011
V
ventura
  • Feb 19, 2011
Re-building our 83 and doors sag. Installed the pin repair bushings, but the holes are worn in the half of the hinge that bolts too the cowl. Where can I buy that part? 50resto only has the bottom door half, which I don't need. Thanks in advance and God Bless. Mike
1987LXragtop
837
Just outside Philly PA
Feb 19, 2011
  • Feb 19, 2011
i found them on ebay once. The bushings were larger for hinges with alot of wear.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 19, 2011
  • Feb 19, 2011
OOOPS!!!The important thing to remember is that the hinge pin isn't supposed to move once you are finished. If it does, then you will end up like me - the pin moved, it wore the door hinge instead of the replaceable bushings. Now in order to fix it right, I had to remove the whole thing again and drill out the hinge to the same size as the bushing and use 2 sets of bushings in each hinge rather than one set.
The fix for the OOOPS was very time consuming and if you aren't up to some very interesting machine work, do it right so you won't have to do it again. I fixed the OOOPS but I had $65 worth of drill bit and specialized reamer plus pulling the fender off to fix it.
I ended up removing the fender and removing the hinge bracket. Set the hinges up in a drill press to insure that the holes would be drilled straight and inline with each other. Getting the hinge bracket set up in the drill press is very important. The top hole and bottom hole are drilled and reamed without taking the hinge bracket out of its mounting on the drill press. This insures that the holes are in prefect alignment with each other.
Then I used a 15/32 drill to the old hinge pin holes out. Next, I used a .4780 straight reamer in the drill press to ream the holes out to the same size as the replacement bushing. Push the bushings in and use a little hard setting Locktite to secure them. If I did it again, I would probably go with .001-.0015 smaller reamer for a press fit.
A word or warning, if you choose this method, mike the bushing OD before you order the reamer. Your bushings may not be the same OD as the ones I used. The reamers can be purchased with almost any size OD you need, but be sure to get the right size the first time.
Drill bit and reamer are available from MSC direct (MSC Industrial Supply Co.)
Reamer P/N 72034788 - $45
Drill bit P/N 84579861 - $17
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Paint and Body replacing door hinges and pins
  • Bsimps
  • Dec 27, 2019
4K
Fox 5.0 Mustang Tech Dec 28, 2019
7991LXnSHO
G
Paint and Body Door pin install question
  • ggradtech
  • Jul 9, 2019
2K
Fox 5.0 Mustang Tech Jul 10, 2019
ggradtech
G
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
21K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
L
Cracking door hinge bushings
  • Lunch
  • Apr 24, 2019
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2019
90sickfox
