84 SVO starting help
seifertjoey
the car will start on starting fluid and run.if i shut it off and try to start again it just cranks until i spray it again?has anyone had this problem?this is my first 2.3 build and i have no clue where to start looking for the problem.the car has already been converted to one pump in tank and a la3 ecu swap,35lbs injectors.just wont start unless sprayed:shrug:
What computer do you have in the car? I my 2.3T stang I had the same problem comes to find out that the computer was shot. Make sure that the fuel pump relay is clicking.(Should be under driver seat)
