86 302 + E7's?
  • Thread starter Thread starter stang9gt
  • Start date Start date Dec 14, 2004
stang9gt
1,247
State College, Pa
Dec 14, 2004
  • Dec 14, 2004
I have an 86 302 mustang motor in my bronco and someone said I can put E7 mustang heads on and get some power.. This true?
BlownStangGT
REPEAT
3,860
Lancaster, PA
Dec 14, 2004
  • Dec 14, 2004
well of course it will....
NKau
1,346
Jefferson, WI
Dec 14, 2004
  • Dec 14, 2004
E7's would provide a decent gain, but if cheap iron heads are what you're after, check into some gt40's or gt40p's. You can find them really cheap, and they would be a much better addition than the E7's. Keep in mind that if you get the gt40p's that you will need special headers to clear the plug wires due to the odd angle of the spark plugs.
stang9gt
1,247
State College, Pa
Dec 14, 2004
  • Dec 14, 2004
E7's bolt right on without any issues? PTV clearance or anything?
D
Daggar
3,902
  • Dec 14, 2004
The problem that you're going to run into is piston to valve clearance. The 86 Mustang 302 has flat top pistons and came stock with roughly 9.2 - 9.5:1 compression. I won't tell you that the E7s specifically will not work (since I've never tried them) but I'm reasonably sure you're going to need to fly cut the pistons to get them to fit. This is most surely going to be the case in the matter of the GT-40s because the valves I think are larger than even the E7s. Your best bet (if you don't want to fly cut the pistons) is to get a set of Twisted Wedge heads for under $1000. So long as you don't exceed the recommended lift, you shouldn't have any P to V problems.
D
Daggar
3,902
  • Dec 14, 2004
Woops... server hickup... double post.
moonenn3186
233
Dubuque, Iowa
Dec 14, 2004
  • Dec 14, 2004
E7's "should" fit without any problem as long as you are using a stock cam - it worked for me some years ago (it was close). According to Trick Flow (high ports at least) will not work w/o fly cutting - same goes for Gt-40 series heads.
The E7 swap is a 20 horse project - but you won'tl feel it till above 4500 where the e6 heads ran out of breath.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Dec 14, 2004
  • Dec 14, 2004
I've heard of people putting E7's on '86 flat top piston motors with no issues, but they had to be really conservative with the cam. I doubt with a stock cam the valves will be open much at all when the engine is at TDC, which is the only place where they could make contact.
stang9gt
1,247
State College, Pa
Dec 14, 2004
  • Dec 14, 2004
The cam I want to run is the comp 260H cause it makes really good torque for 4x4 applications.
BlownStangGT
REPEAT
3,860
Lancaster, PA
Dec 14, 2004
#10
  • Dec 14, 2004
  • #10
just forget about the heads if u wont feel anything till above 4500
NKau
1,346
Jefferson, WI
Dec 14, 2004
#11
  • Dec 14, 2004
  • #11
http://www.carcraft.com/techarticles/50452/index5.html
Remember seeing this article a while back. Seems like it would be a pain to do, but if you notch the pistons, you could run whatever head/cam combo you desire.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Dec 14, 2004
#12
  • Dec 14, 2004
  • #12
My plan was to put my E7s on an 86 short block, and port the heads. I have heard they fit fine, but I would check with those who have done it before!
D
Daggar
3,902
#13
  • Dec 14, 2004
  • #13
Here's the link for hte twisted wedge incase you wanted more info on them. If you download the PDF file you can bump the cam you intend to run against the figures they provide for the 86 flat top pistons to make sure you don't have too much cam.
http://www.trickflow.com/product/heads/twisted_wedge/pr_twiswedge.htm
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Tuesday at 2:05 PM
Kleinjj27
K
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
