86 5.0 fires then immediatly dies
91lxvert
110
my friend has a 86 5.0 with 78k
he just changed the upper and lower intake gaskets
car fires easily and for the second its going sounds fine, b8ut it just shuts off, it doesent stumble or anything
dist is in correctly, sparkplugs are new and gapped correctly, spark plug wires are correct
tps is at .98
can hear the fuel pump prime, two clicks from under the hood
crank it, car fires up to 2k, then shuts off immediatly
almost as if something is not telling the fuel pump to turn back on after the prime
anyone got any ideas?
thanks
does it fire back up after it dies?
were it me, i would have a FP gauge hooked up and an inductive light on the coil wire - try to see what you are losing.
one could try to pull codes for fun, too.
good luck.
yeah you can stqart it as many times as you want, just dies instantly
ok if either its loosing fuel or spark where should we look to remedy this problem?
thanks
A fuel pressure guage I think is going to be your best bet at this point. At least you'll be able see what's going on. My guess is that your fuel pump relay is good but the fuel pump itself is bad... gas leaking through the seals or check valve in the pump and going right back into tank instead of the fuel lines when it's running (saw this once before). A guage will be able to tell you and also help rule out the regulator and return system. Hope this helps.
I had the same problem, posted it and got the right answer for what was wrong with MY car. Mine would fire right up, then die-the tach would go to zero, heard the fuel pump shut off. I could just touch the ignition and hear the fuel pump go on and the gauges move- in other words the ignition wouldn't stay where it needed to to keep electrical working. I could barely wiggle the ignition lock and things would come on and shut off.
I replaced my ignition lock (the key assembly) for $11, still didn't fix it. Then I replaced the ignition SWITCH (located on the steering column under all the trim pieces-$10) and now it works perfectly! :)
I hope yours isn't more complicated than this, try turning the key to the start position and move it back and forth with just a little pressure- if things cut on and off there is your problem. Good luck!
I ran into a kid with the same problem. He actually had the starter solenoid wired up wrong. He had the wire for the fuel pump on the starting side, so it only got juice when cranking, then would stop pumping and die. Just something to look at.
