86 GT Gauge question
I know the stock gauges suck, but they're all I have right now. Seems like every now and again, the oil pressure gauge, the gas gauge and the temp gauge will read higher than normal all at the same time. Sometimes, if I shut the car off and restart, the gauges read normal. This is the second gauge cluster I've had in the car and the first set did the same thing. Has anyone else experienced the same thing? I figure this is a wiring problem, but does anyone have any suggestions as to where to start?
Does this occur when you switch your headlights on? Alot of people report there stock temp gauge climbs when the headlights are turned on. Could be a couple of things, one would be a loose ground the other would be the IVR (instrument voltage regulator) on the back of the cluster, but since this is your second cluster I would rule out the IVR and start checking all of my grounds. Especialy the block to firewall ground.
I know how to fix the problem. Do what I did.
You know, I've not noticed if it's with the lights on or not. I'll have to check that out. I'll check the grounds also.
stang1986GT said:
Very nice. How did you mount those? Did you use the same wiring? Give us more details!
yes, those are great. If i could do something like that at a fraction of what the Florida5.0 cluster costs ($750ish w/gauges :notnice: ) i would do that in a heart beat!
This is how I did it. http://www.flemworld.com/Hto/gauges.html
I only used the stock fuel sender, power, and ground wires. I ran my own wires for everything else. I didn't do it the exact same was as the guy in the link did it. I modifed the rear of the cluster to fit over the all of the gauges. My old cluster was too brittle to just use the end piece. It took me a good week or 2 to do, I also ended up frying an sport comp electronic 160mph speedo lol but I lied and got my money back from summit lol. If you have an questions or if you want more pics PM me.
Awesome...thanks so much!
