86 Stang Headache continues....
93 LX
3,081
Norwalk, CA.
Still having Thermactor errors.
Checked solinods - all test OK. Applied voltage and all click, vacuum flows through solinoid.
Check Vacuum - all solinoids do not flow vacuum.
Traced wires to computer - all test OK.
12 volrts present at solinoids when car is running.
Out of ideas, could the computer be hosed? Computer is SD the number is VJ1
Also I found one pin boiken, its pin 4. That one goes to the TFi through a 22 ohm resistor. For now I will just wedge it in but I will make a trip to the bone yard and i could cut this pin off another harness to replace the broken pin.
Should I move to Mass Air at this point or will this still be a problem? I dont want to troubleshoot 2 problems at once.
Thanks for any help you can offer.
Allen
