87 Ecm Question
  • Thread starter Thread starter Fordman91
  • Start date Start date Aug 15, 2017
F
Fordman91
  • Aug 15, 2017
I am working on building an 87 E7 HO motor. (Not Cali standard) The ecu I need is the 78-4484, but it doesn't seem to be available anywhere. The car it will be going into is an automatic with SD. I am not looking to convert it to maf or a manual. So, my questions are would I be able to use the 86 ECM 78-4397? Or the 87 78-4503 (with Cali)?
I have cross checked the 78-4503 and it is also used on the 88 model (maf). So I'm not sure of the 87 Cali ecm would maf also?
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Aug 15, 2017
  • Aug 15, 2017
1986 thru 1988 are speed density other than 88 Cali cars. I am not sure if the pinout on the ECU changed for 1988 due to mass air being available.
Ecus are usually distinguished by a 3 letter code. Unsure what that codes for 1987 are.
Unsure if 1987 uses the same ECU
My '88 auto ECU will be available if I can perform my MAF swap anytime soon
F
Fordman91
  • Aug 15, 2017
Looks like rockauto has the 88 and 87 ecm that I need listed as the same part number, which I can't seem to find in stock anywhere. But that's definitely good to know!
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Aug 15, 2017
  • Aug 15, 2017
list of ECU codes I've found care of jrichtker
All the following are mass air unless they say Speed Density
8LD - MANUAL 88 5.0L Mustang Speed Density
8LF - Auto 88 5.0L Mustang Speed Density
A9L - 89-93 5.0L Mustang 5-spd Mass Air
A3M - 93 5.0L Mustang 5-spd Mass Air
A3M1 - 93 5.0L Mustang 5-spd Mass Air
X3Z - 93 5.0L Cobra 5-spd Mass Air internally calibrated for 24 lb injector
A9P - 89-93 5.0L Mustang Auto Mass Air
A9S - 88-93 5.0L Mustang California Mass Air
C3W - 89-93 5.0L Mustang Auto
DA1 - 87 5.0L Mustang 5-spd Speed Density
VM1 - 86 5.0 5-SPD speed density
VJ1 - 86 5.0 AOD speed density
Ironically I can't find an 87 AOD code anywhere. This is what I'd search for on eBay to find an ECU
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
