87 Gt With A 347 Problems
Dusten Hammond
Spring I decided to buy a 347 Stroker SB from TRE Performance. I built the block up a tad (Budget build) had it installed by a local Mechanic it ran with the speed Density pcm but barely Cause you all know that speed Density don't play nice with mods. I ended up buying a MAF Conversion kit from fiveology racing (A9P PCM, MAF harness, meter calibrated to my throttle body & injectors, directions on how to rewire the stock harness. ) followed directions Correctly. When I go to turn the key, I don't hear my fuel pump prime and out of Curiosity, I tried to Crank my car and nothing. I have dash Lights (Check Engine &Brights indicator ) but nothing else
Thought I messed up somewhere I decided to get an 89 Harness and run that, same issue
So... I thought the PCM was the issue, I sent that back to Fiveology and got a replacement. We tested it in my friends 90 GT and it worked without issue. Tried to install it in my 87 and same problem: No pump or Crank but all dash lights. The Mechanic put his Scan Tool to it and he said he can't read the PCM...
I'm at a loss for what to do. An ASE certified Mechanic is "Confused as F*ck " And the Local Ford Dealership Service department won't touch it. Any help would be appreciated. What should have been a easy swap is costing me a butt ton of cash...
@jrichker to the rescue?
Can you run a code test?
There has to be something mis wired, or maybe the fuel relay just picked now to go kaputz. There is a way to jump the test harness to run the pump and jrichker has it posted many times.
Those are the three places I would start.
I took the Mustang to a shop and $660 later it finally runs...just in time for Winter too! /s
The mechanic didn't tell me what he did or how he did it either. Probably wanted me as a returning customer if anything went wrong.
Now I just have the overheating starter issue and Dim tail lights. Minor inconveniences. At least I got 5 months to fix that. [emoji3]
Overheating starter? Makes me wonder if you will find something related to both issues or if he fixed it already. Anyway, j has a very thorough write up on the starting system to help you.
As requested...
No Crank checklist for 5.0 Mustangs
Revised 05-Oct-2010 to update Fluke references.
No crank. slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of both no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a know problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstick and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .5 volts across a connection indicates a problem.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachment.php
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
attachment.php
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
attachment.php
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
attachment.php
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
attachment.php
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
That is a handy guide. I'll take a look this weekend. I noticed that it does smoke a tad when I drove it 10 miles this last weekend. I thought it was just engine break in smoke...
