Well for anybody who has done this before, any advice or tips would be great. I could also really use some headlight wiring diagrams for both the 86 GT and the 87 GT because the 86 put all the connections under the hood on one harness that plugs up under the dash, while the 87 dash harness includes alot of the under hood stuff up to the starting solenoid, and then has a plug for the headlights and whatnot. the colors aren't the same between the two, surprise surprise, and I'd rather not hack this one up too too bad.
Also the main wiring harness in the 86 has one wire that comes all the way across the dash and plugs into something down by the driver's side kickpanel. The 87 harness doesn't have this, or it's done a different way. I'm not sure what it is for. I know someone here has been nuts like me and done this before, lay your wisdom on me.
Thanks in advance,
~S
Thanks in advance,
~S
