Progress Thread '88 GT Hell Horse - All over the place
  • Thread starter Thread starter stanglx2002
  • Start date Start date Jan 12, 2018
  • Tags Tags
    4r70w digital dash megasquirt paddle shifters raspberry pi s197 seats
  • 12
  • 13
  • 14
  • 15
  • 16
  • 27
First Prev 14 of 27 Next Last
stanglx2002
CT Material here
1,563
1,110
164
Dec 5, 2018
#261
  • Dec 5, 2018
  • #261
Update:
I got both of my parts in the mail today RPi and Serial to USB adapter. I went out and tested the new cable, and it still powers ON the RPi with the power supply off - FAILED TEST. I then pulled out the new RPi, pulling in all the connections again, and it still powers ON the RPi - FAILED TEST.
So I am for some reason have an issue when you connect the MS ECU to the RPi with the Power Supply connected it can boot-up still??????
@jrichker do you have any input on my above issue? I am out of thoughts other than putting a diode on the micro USB cable that comes from the power converter in the power supply to protect it from somehow pulling power to bootup? If you think that will work what diode do you recommend?
stanglx2002
CT Material here
1,563
1,110
164
Dec 6, 2018
#262
  • Dec 6, 2018
  • #262
So, I did some further investigation on the boot-up issue that I am having. I was able to backtrack through the wiring of the power supply, and I believe to have identified the issue. It seems that the RPi is robbing from both the Power Supply and the ECU to complete the circuit, which explains why I dont have any issues at all when the ECU isnt plugged in. I will be adjusting the relay wiring in the power supply this weekend to correct this, and then retest to see if it corrects the issue.
Reactions: wiseguyk and RaggedGT
stanglx2002
CT Material here
1,563
1,110
164
Dec 8, 2018
#263
  • Dec 8, 2018
  • #263
I was able to test my theory out on the wiring for the power supply, and all tested out great! It all works as planned and the boot-up issue has been resolved. Since the testing worked out I decided to go ahead and epoxy the power supply. It is now curing until tomorrow, so I can put everything back together on the car for a final test and possible video.
I also have some really good news in that my parents called me up asking what I wanted for Christmas. I told them my plans for the car, and I was planning on rebuilding the 331, adding a turbo, and WMeth Injection. They asked if they could get the WMeth system for me, which of course I couldn't say no. I was planning on piecing together a system to meet my needs, but when I priced all the individual peices it was cheaper for a standard kit. I liked the DevilsOwn WMeth Systems, and there standard kit gives me all the pieces for the system without the tank and extras I didnt want. So when checking our I normally look for a coupon. They are having a sale until tomorrow for 50% OFF there kits using the PRI2018 code, so I got there standard kit with (2) nozzles (7 & 10) and added there in-line filter for $182.
Good Day Today
Reactions: General karthief and RaggedGT
stanglx2002
CT Material here
1,563
1,110
164
Dec 9, 2018
#264
  • Dec 9, 2018
  • #264
Video Time:
I was able to epoxy the power supply yesterday and was dry tonight. It takes a little longer to dry now that it's getting colder. I put everything back together and took a short video. Not the best video but hope you guys enjoy it.
View: https://youtu.be/phGPq_bDZ6Q
Reactions: 90sickfox, RaggedGT, Steel1 and 1 other person
CarMichael Angelo
8,909
234
Birmingham, al
Dec 10, 2018
#265
  • Dec 10, 2018
  • #265
I think it's amazing. I want one.
For me though, it would have to be installed as a tuning interface, and a second set of instruments to check the ones in front if my face.
wiseguyk
5 Year Member
Sep 23, 2016
302
85
58
Florida
Dec 10, 2018
#266
  • Dec 10, 2018
  • #266
Wow, great job Kurtis! I know you've shown us the splash screen before, but I love it and it looks so slick while booting up. Nothing like giving a 20+ yr old car the new Ford Sync vibe
I'm curious about the timer LCD on the power supply. The "100" means it will wait one minute before shutting down? What does the "200" then mean after it's shut down? Just a status code that it's off and waiting to be powered on again?
Any way to make that timer actually tick down as a way to see how long before it shuts off? I know once it's installed and configured that won't really be necessary, but if it ticked down (like a bomb hehe) it would be a really easy way to tell that the timer script and everything is functioning as opposed to just having a static value shown there
stanglx2002
CT Material here
1,563
1,110
164
Dec 10, 2018
#267
  • Dec 10, 2018
  • #267
You could for sure install one that way. I figured some people wouldn't want to replace there instrument clusters, so its just a HDMI and micro USB connection for display and power. This makes it universal.
stanglx2002
CT Material here
1,563
1,110
164
Dec 10, 2018
#268
  • Dec 10, 2018
  • #268
Thank you! I thought it is a good addition to the car getting it into the 21st century, but also removing the analog "dummy" gauges that inaccurate most of the time.
Good questions on the power supply, and sorry for the sideways video shot of it. The LCD screen that you saw the "002" is displaying the amount of time until the power supply will Turn OFF. I reduced this time for testing purposes, and will be increased to "030" or 30 minutes once put to normal use. This timer counts down the time until the power supply turns itself off, and is independent of the computers shutdown timer to not effect each other. The (2) led lights also help to tell you if it has power (red) and also if the power supply is ON (blue).
General karthief
Mod Dude
Aug 25, 2016
28,047
10,666
213
polk county florida
Dec 10, 2018
#269
  • Dec 10, 2018
  • #269
Can you add some anti theft type stuff to it like facial recognition or thumb print start? Just wondering.
stanglx2002
CT Material here
1,563
1,110
164
Dec 10, 2018
#270
  • Dec 10, 2018
  • #270
Both items are possible to do
stanglx2002
CT Material here
1,563
1,110
164
Dec 13, 2018
#271
  • Dec 13, 2018
  • #271
I hope that you guys enjoyed the video as I know it wasnt the best in the world. I plan on getting another video of it out on the road hopefully this weekend, but have been very happy with the new dash so far.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Dec 13, 2018
#272
  • Dec 13, 2018
  • #272
Very much looking forward to seeing the dash in action.
wiseguyk
5 Year Member
Sep 23, 2016
302
85
58
Florida
Dec 13, 2018
#273
  • Dec 13, 2018
  • #273
Yes! I wanna see some video of the dash during a couple WOT pulls
General karthief
Mod Dude
Aug 25, 2016
28,047
10,666
213
polk county florida
Dec 13, 2018
#274
  • Dec 13, 2018
  • #274
I just want to see tire smoke and long black marks on the road!
stanglx2002
CT Material here
1,563
1,110
164
Dec 14, 2018
#275
  • Dec 14, 2018
  • #275
Doesnt look like the video will happen this weekend. Nothing but rain in the forecast
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,946
5,818
213
Dec 14, 2018
#276
  • Dec 14, 2018
  • #276
That is awesome !!! Definitely marketable too. Can't wait to see it actually reading the data.
Looks really good. Great work !!!
stanglx2002
CT Material here
1,563
1,110
164
Dec 14, 2018
#277
  • Dec 14, 2018
  • #277
Thank you!!! I will have to get a quick video of just the car running to show the dash showing values for everyone.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 15, 2018
#278
  • Dec 15, 2018
  • #278
How long between the time that you attempt to start the engine and the display becomes fully active and usable?
stanglx2002
CT Material here
1,563
1,110
164
Dec 15, 2018
#279
  • Dec 15, 2018
  • #279
It takes 28 seconds from activation of the power supply via ignition turned ON to display of gauges connected to the ECU.
Admin Dude
Jan 4, 1985
43,353
21,555
234
Box behind Walmart
Dec 15, 2018
#280
  • Dec 15, 2018
  • #280
You might snap up another Pi sometime in the future and try a lighter distribution of Debian. If you're running the full blown version of the Pi distribution, it's loading many things that are not necessary to support your application.
You could probably cut that time in half with a bit of tweaking. You probably don't need any of the Debian GUI at all.
  • 12
  • 13
  • 14
  • 15
  • 16
  • 27
  • Locked
Expired 2009 Mustang Gt Premium Track Car
  • Phillip Moore
  • Dec 15, 2014
  • S197 Mustangs For Sale (2005-14)
2K
S197 Mustangs For Sale (2005-14) Dec 15, 2014
Phillip Moore
  • Locked
1998 Mustang GT 5 speed
  • Jkstang78
  • Feb 18, 2011
6K
SN95 Mustangs For Sale (1994-04) Feb 18, 2011
i3oosted
I
  • Locked
2005 Supercharged Mustang GT-w/full body kit - $23,000
  • SoCalSQ
  • Jul 27, 2011
4K
S197 Mustangs For Sale (2005-14) Aug 5, 2011
SoCalSQ
  • Locked
1994 Mustang GT Built. 331, C4, coilovers, gears,spool etc.
  • 5.0 gt dreamer
  • May 19, 2011
5K
SN95 Mustangs For Sale (1994-04) Sep 7, 2011
SQUEEZE&STROKE
F
  • Locked
97 5 spd Cobra convertible w/ Maximum Motorsport Max Grip - street fun, track, HPDE
  • FirstOnRaceDay5
  • Mar 16, 2010
4K
SN95 Mustangs For Sale (1994-04) Apr 27, 2010
FirstOnRaceDay5
F
