88 Maf Conversion Done Wrong By Po
jrp27540
173
35
38
So my 88 LX has been running pig rich and randomly dying when reaching normal operating temp. I have also had issues getting the key on codes to dump, so I have been on a mission to reverse engineer everything that the PO did.
Tonight I retraced his MAF conversion. Ends up he didn't move the white/red nor green/black wire. I'm not sure if that will solve the richness issue nor getting the key on codes, but I'll find out tomorrow.
My question is if someone would be able to confirm if he hooked the 4 wires from the MAF harness correctly. The red and black are correct, but I'm not sure on the other two colors. The harness he used had a green and yellow wire. He put the green in pin 9 and the yellow in pin 50.
Does that sound right for the color of the wires?
Thanks all!
What model computer? - A9L (5 speed), A9S (California) or A9P (auto trans)?
Can you get the codes to dump? If not then you have computer or wiring problems.
See below for a Mass Air wiring diagram for 88-90 Model 5.0 Mustangs...
The following are diagrams courtesy of Tmoss & Stang&2birds
Complete computer, actuator & sensor wiring diagram for 88-90 Mass Air Mustangs
a9x-series-computer-connector-wire-side-view-gif.71316
eec-iv-computer-connector-for-5-0-mustang-gif.88243
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
TFI module wiring for 94-95 Mustang GT
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-IgnitionControlModule.gif
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
Engine mounted fuel injector harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangEngineHarness.gif
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/TPS_IAB_Pic.jpg
Starter circuit
http://forums.stangnet.com/attachment.php?attachmentid=21328&d=1080916057
Alternator diagram for 94-95 Mustangs.
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-Alt.gif
Thanks for the info. It looks like the other two wires are fine. I am now able to get the key on codes with no problem. Ends up the code showed that I had a bad coolant temperature sensor, which was causing the car to die and not start after getting to normal driving temp. I replaced the sensor and the problem is gone and the codes are clear. Thanks for the help!
